Thread: If no numbers on case how to spot a 901/02 engine?
    So now I understand that some engine cases were replaced (under warranty) with unnumbered ones the question becomes: How to spot a 901/02 engine on the outside (forgetting about the red shroud, carb's etc)? Or is the case of the 902/01 engine exactly the same as the 901/05 or 6, but was it just a number to show it was a S or a normal 2 liter?
    thx
    Wiebe
    Turf
    10/66 911S coupe
    87 911 Carrera Convertible
    Oct 2008
    Burford, ON, Canada
    Considering the age of the engine there could be anything inside. The only way to know what is there is to disassemble it. This is true of any engine, numbered or not. Heads and pistons are more important than the case to detrermine the engine type.
    Restoration newbie.
    Jun 2007
    San Francisco
    Heads, pistons, cams, and rods are different for 911S. Also, the Webers
    should be 40IDS although early cars came with 40IDA with an S stamped
    somewhere else I believe.
    andy
    67S in pieces
    EarlyS: 1358
    [SIGPIC][/SIGPIC]
    Bottom side of the heads has a casting number that is a clue
    Alu S cases are the same as normal except for the numbers.
    Quote Originally Posted by ajwans View Post
    andy
    FWIW-I posted a pic of the "S" here at the bottom of the page.
    http://www.early911sregistry.org/for...t=19424&page=3
  1. Replies: 25
    Last Post: 10-27-2014, 06:12 PM
  2. Case numbers questions
    By mpotvin in forum General Info
    Last Post: 02-03-2012, 06:44 AM
  3. Case numbers help needed
    By BOYER73S in forum General Info
    Last Post: 12-15-2008, 05:24 AM
  4. Replies: 2
    Last Post: 11-20-2008, 11:50 PM
  5. Valuation of 72 S chassis w/matching numbers case
    By pu911rsr in forum General Info
    Last Post: 05-12-2007, 08:05 PM
