Results 1 to 8 of 8
Thread: Sway bars on '70 911T
    Junior Member SteveD's Avatar
    May 2007
    Ohio
    New guy here but have been reading the board for about a year and a half. I have a 911T with no sway bars. Last winter, I replaced all the shocks (Bilstiens) and brake lines and had the wheel bearings replaced and had the car lowered to European height ride.
    This winter, I'm planning to add a 19mm weltmeister sway bar to just the front since it's pretty straightforward (mounting hardware's there from the factory). Would this be too much bar for the front? It's mostly a road car that I enjoy through the twisties with maybe 1-2 DE days per year. What do you guys think?
    Steve #1416
    '57 MGA Roadster - Black
    '70 911T Coupe - Tangerine
    '83 SAAB 900 Turbo - Charcoal
    '03 SAAB 9-3 Vector - Black
    Apr 2003
    Portland, OR
    I have a '73T with 19 mm front and rear bars. After some initial adjusting to get the ride where I like it, they work fine. I do monthly Autocross and tours in the countryside.
    Harry
    Member #789
    2009 MB C300
    Senior Member Neunelfer's Avatar
    Dec 2002
    Sandy, Utah
    19mm should be fine.
    I'm using the Turbo 18mm and it's perfect IMO.
    Eric - Sandy, Utah
    71 911
    914-6/GT
    914-6/ORV
    87 944 Spec 1
    Porsche Truck
    62 Beetle
    80 VW “Caddy” Pickup
    72 R75/5 Toaster Tank
    PMB Performance
    Love Us On Facebook
    I can't say I've driven a 911 with only a front bar. With stock 15s front and rear a 911 has a fair bit of intial understeer. I would think a 19 up front and nothing on the back would make the car really plow.
    Tom F.
    '67 911S Slate Gray
    '92 964
    #736
    Jan 2006
    Naperville, IL
    I have an H&H 19mm in the front only; It provides a much improved turn in over no sway bar. Too much speed/confidince can cause the heavy end to push out further than you may intend....
    -Andrew
    '72 911E
    '82 931, '92 968, '93 968
    S Reg #1074
    May 2007
    Ohio
    Thanks for the replies. I was worried about the car plowing but with the mixed replies, maybe it's not so bad. Considering I've already seen my rear end come all the way around, maybe I should just put a sway bar on the front to save myself from myself:D
    Steve #1416
    Feb 2005
    Montreal, Canada
    With Weiltmeister bars : is it possible to keep the original arms and drop links, and just upgrade the cross bar to keep the original look ?
    JD
    Dec 2002
    Sandy, Utah
    If you have the part numbers on the factory bars they (used to be) fairly inexpensive. You could get the 18mm bar and use your drop links and arms. The arms wouldn't have the reinforcement the 18mm bar arms have but, those are easily made I would think.
    Eric - Sandy, Utah
    71 911
    914-6/GT
    914-6/ORV
    87 944 Spec 1
    Porsche Truck
    62 Beetle
    PMB Performance
    Love Us On Facebook
  1. RSR Sway Bars
    By letsrollbabe in forum General Info
    Last Post: 02-20-2017, 08:02 PM
  2. Which Sway bars?
    By Veronica87911 in forum Technical Info
    Last Post: 11-19-2013, 06:19 PM
  3. FS: @eBay - 1972 Porsche 911T TTG, S Trim, Sway Bars, non sunroof
    By hwgunner in forum For Sale/Wanted: Early 911 Cars, 1965 - 1973
    Last Post: 02-02-2013, 10:45 PM
  4. WTB: H&H sway bars
    By Flat Six, inc. in forum For Sale: 911 Parts
    Last Post: 02-12-2008, 02:12 PM
  5. Sway bars
    Last Post: 10-14-2005, 04:34 PM
