Results 1 to 10 of 15
Thread: 1972 911s Fuel Injection Pump Rebuilder?
    Any leads? Gus At Pacific fuel injection is very backed up.
    Thanks!
    Steve
    Henry at Supertec?
    Early 911S Registry #931
    1971 911 2.2T Coupe Tangerine
    Jan 2006
    Naperville, IL
    Steve,
    How "backed up" is backed up? I was looking at a Christmas gift for myself...Do you happen to know the approx. cost too.
    -Andrew
    '72 911E
    '82 931, '92 968, '93 968
    S Reg #1074
    H&R Fuel Injection 1648C Locust Ave. Bohemia N.Y. (don't have their ph. # here at home.)
    Apr 2003
    NoCal
    NObody beats Gus for long time quality and doing the job right the first time. There may be other quality rebuilders but I haven't talked to anyone that got 100% work elsewhere. I haven't needed his services in a while but if you have to ask about cost.... you had better be sitting down when you talk with him.
    If you are in a big rush, you MIGHT check for a local BIG RIG workshop and see if anyone there rebuilds MFI. A lot of the older diesels used them and a fair amount of the truck shops knew how to work on them. A long time ago I badly needed to get a turbocharger resealed and the best local shop was Garretsons. They were backed up and I needed it NOW. I didn't want to waste the $$ on replacement as mine was in great shape expect for a burned out seal. I was referred to a truck shop by someone on one of the local IMSA teams. I went with my turbo & discovered one of life's dirty little secrets... Garretsons sublet their turbochargers out to this truck shop. I personally saw all the turbos sitting there. It was later verified by one of the race shop's employees... so you could find what you need a lot closer than you might realize [but after this experience I NEVER again accepted what I was told over the phone about something like this].
    Good luck
    JR
    Jan 2006
    Naperville, IL
    Quote Originally Posted by MoparBoy72 View Post
    Steve,
    -Andrew
    '72 911E
    S Reg #1074
    Jul 2006
    Corvallis, OR
    Henry Supertec 760-728-3062.
    72S, 72T now ST
    Henry @ SuperTech. Gus is good too . I've used them both and like Henry the best.
    JW
    72T Coupe - hotrod.
    72S "Tangie"
    73S Poop Brown
    69T Irish Green
    69S Secret Project
    S Registry Dues Paying member #1438
    Many thanks for the tip to use Supertec. Pump is done, just arrived from Henry today. Very good service.
    How much for rebuild?
  1. Replies: 3
    Last Post: 02-24-2014, 03:02 AM
  2. 2.2L 911S fuel injection pump Bosch overhauled $1,000
    By typ901 in forum For Sale: 911 Parts
    Last Post: 04-19-2012, 04:31 PM
  3. Rebuilder for MFI FUEL (ie. not injection) pumps?
    By obrut in forum Technical Info
    Last Post: 03-20-2012, 08:38 AM
  4. 1973 911S 2.4L Mechanical Fuel Injection Pump
    By Wildman805 in forum Technical Info
    Last Post: 07-08-2001, 11:53 AM
