I need some translation help.
If a car came w/ a Schubwelle what could that have been? Is it possibly an emergency rope?
Richard
Richard
no, itīs a rotational wave... whatever that might be...
all I can say that it has to be a part inside the engine.
I don't think this one of those words with a literal translation.
Ze German is correct in the literal meaning of the words.
"Schub" also is part of the word for drawer ( like in to hold something).
"Welle" literally means waves but also means corrugated or billowed like a soft pocket.
I believe this means a folding storage compartment of some sort, I suspect a door map pocket or storage bin behind the front seats.
Maybe someone else can chime in who is more familiar with automotive terms in German.
They had an option for a rallye storage bin which went across the rear seat panel. It was divided into 3 sections and hung upright in the rear.
I have also seen a photo posted that showed a map pocket for the navigator
located on the right door panel.
I recall it having a latchable cover like a Pendaflex folder, perhaps that is what it refers too?
I think both Turboman and Johns4949 are looking in the right direction.
I would translate welle as cable, since a tachowelle is a speedo cable. Combine this with Schub being drawer and you have indeed a storage device.
Does any one know the VIN of the green 911 at Bruce Canepa that has such a storage device?
Richard
Is this not a serated type lock washer? It's been thirty plus years since the German class. I will ask the instructor at dinner this evening.
Bill Barnich
R Gruppe Nr.230
Early S Nr.960
71 911T/2.7 Tangarine
73 911?/3.6 work in progress
Another literal translation for the word could be: pushrod
Among the various meanings of the word SCHUB: push, if used as a verb
WELLE is used to describe a rotating shaft, as in kurbelwelle (crankshaft) or nockenwelle (camshaft).
I don't believe the term could be logically stretched to refer to the rally storage bin mentioned above (see photo below of the device in question, from the silver /green car at Canepa Design)
JZG
