Thread: shims and spacer, did the factory used them
    Jul 2008
    near Ottawa, ON,canada
    As i am building the rack to hold the car to do the rust surgery, i do all the door alignment now , using the measurement from a great fellow here , set everything up , but here is where it is weird, both the latch stricker and the hinge have shims or spacers, plastic on the latch an galvanised on the hinges
    they dont seems to be home made but , after seeing what the (reputable shop ) did , i have serious doubt that the factory used them
    in the even that they did, how many is considered a maximum, are they the plastic and steel
    thanks again
    my car has shims on the hinges and striker.
    i am sure they are factory.
    the hinge ones are metal, the striker
    shims are plastic
    i cannot tell you what the maximums would be.
    bob moglia
    '72 E sunroof coupe
    Apr 2004
    Ontario Canada
    I have a shim under the lower hinge on my drivers door. I looked on PET and it shows the shim and calls for a quantity of 4. Part # 901 531 391 20 they call it a desk pad.
    Clarence
    Clarence
    72 911T Irish Green
    81 931 Minerva Blue
    84 Carrera Targa Guards Red Sold
    71 911E Yellow
    72 911T RS look project White
    Jul 2008
    that the first thing the shop
    cool thanks, ičll put them back on
    i guess the plastic shims are not painted, but were the steel one done or just galvanised finish
    for once things are right,,
    These are hand built and individually fitted cars, the plastic striker shims and the galvanized hinge shims are fitted as needed as the car is assembled. There is no specific number, just whatever is needed. When the door is removed the proper way to do it is to remove the hinge pins, otherwise you'll be doing all that factory gap fitting all over again. I trust the body dimension diagram will help.
  1. 2.0L copper cylinder base shims
    Last Post: 02-14-2014, 04:20 PM
  2. Did factory use shims to adjust hood and frunk lids?
    By Mark Wilson in forum Technical Info
    Last Post: 10-01-2013, 10:17 AM
  3. WTB: Door Striker Shims
    By SKWIKY67 in forum For Sale: 911 Parts
    Last Post: 04-11-2013, 04:35 PM
  4. FS: Thin Door Striker Shims
    Last Post: 10-26-2009, 01:49 PM
  5. Weber Float Adjusting Shims
    By bhaubold in forum Technical Info
    Last Post: 10-26-2007, 06:01 AM
