Thread: bosch fuel pump prefilled? (carbs)
    Apr 2004
    Ontario Canada
    Hi,I have replaced the housing o-ring on my pump and because it was totally full of fuel when I opened it up, I am wondering if it must be filled before installation. Is there a risk of ignition if not completely filled inside? How would a new or rebuilt come? I know the fuel cools the motor.
    5 years ago when I brought this car to life the pump was full of gummy varnish and did not work. After I had cleaned everything inside the electric motor I filled it with varsol/solvent before staking the housing back together as I was nervous about sparking causing a serious problem. It worked great.
    Do I need to do this again? Has anyone installed a new or used one right out of the box? Are they dry inside? Or am I being over cautious ?
    thanks
    Clarence
    Clarence
    72 911T Irish Green
    81 931 Minerva Blue
    84 Carrera Targa Guards Red Sold
    71 911E Yellow
    72 911T RS look project White
    You're being a worry wart! However, what you do need to do since the fuel also provides the lubrication for the pump, is to cycle the ignition on/off in short spurts until you hear the pump load down indicating it is now full.
    Apr 2004
    Ontario Canada
    Thanks Ed, I'll do that.
    Clarence
    Clarence
    72 911T Irish Green
    81 931 Minerva Blue
    71 911E Yellow
  1. Fuel Pump: MFI vs PMO Carbs
    By Djthom in forum Technical Info
    Last Post: 03-08-2014, 01:08 PM
  2. Replies: 3
    Last Post: 03-09-2013, 08:14 AM
  3. Fuel pump suggestions for big PMO carbs???
    By endo911rs in forum Technical Info
    Last Post: 01-07-2013, 03:26 PM
  4. WTB: Bosch Fuel Pump (for carbs), P/N 91160810700
    By 72Group4 in forum For Sale: 911 Parts
    Last Post: 01-02-2013, 09:29 AM
  5. Facet Fuel Pump for Carbs
    By ErVikingo in forum For Sale: 911 Parts
    Last Post: 02-20-2007, 07:12 AM
