Results 1 to 10 of 10
Thread: Extra oilcooler or aftermarked A/C?
    Pay to play Schiefer's Avatar
    Jun 2008
    Norway
    Hi all!
    I found this strange cooler inside the rear left fender on my car. First I thought it might be a second external oilcooler, but now I suspect it has something to do with the A/C. Have never seen a cooler placed here, what is it???
    Regards,
    Radmund
    S-Reg #1382
    67S Lavender
    It is an additional A/C condenser, used on some A/C kits depending on brand.
    Jun 2008
    Norway
    A/C pictures
    Posting some pictures of the A/C. Itīs supposed to be dealer installed, but I donīt think itīs OEM. Would be very happy to get an answer. The car has had rear wiper before the A/C, so if itīs not original, I will replace it with a rear wiper system.
    The Airconditon is called: Frigette mobile air systems. In the smugglers box I can read: Air Conditioner, Drier Filter Receiver.
    R
    S-Reg #1382
    67S Lavender
    Jun 2008
    Norway
    Thanks!
    Thanks! That was quick
    If you take a look on the other pictures, could you also tell me if this A/C is OEM, period correct or just junk that I should rip out?
    Radmund
    S-Reg #1382
    67S Lavender
    Where is the evaporator? The drier is usually in the wheel well on the drivers side front and the evaporator/blower motor rests in the smugglers box.
    Definitely not a factory setup.
    Tom
    Early S Registry #235
    rgruppe #111
    Jun 2008
    Norway
    Thank you very much Tom.
    You get a very "cheap" and plastic feeling of this A/C, I have hated it for a long time now. Iīm working to get confirmed that the rear wiper was factory installed, missing info in the Stuttgart archives.. But it would be wonderful if I could get it back in place. Better with an extra wiper here in Norway, much rain and low tempratures... A/C is a total waste here
    But what about the compressor, is that one also of a later type?
    Regards,
    Radmund
    S-Reg #1382
    67S Lavender
    Yes, the compressor is of a later style, not a type that was used "back in the day" It would have been a 2 cylinder piston type, actually the compressor looks like the best part of that system. Like Tom said, not a factory type system, in fact it's not even a good aftermarket system, at least as far as the mechanics of the system. I would do my best to eliminate all evidence of that system!
    Jun 2008
    Norway
    Yes Sir!
    Will do!!!
    S-Reg #1382
    67S Lavender
    Worm gear hose clamps on high pressure refrigerant hose. Not factory.
    Sherwood
    rear condenser
    Carefully remove the rear condenser in the fender and you will find a buyer for it. Photograph the mounting points before removal. Extra condensers are always good in an A/C.
    The question about the evaporator, probably combined into the under dash system. Not too unusual. Definitely not worth keeping IMHO.
    Olin - Member #1375
    1972 911T
    Original
    Options added
  1. Extra tag next to VIN plate
    By pu911rsr in forum Technical Info
    Last Post: 06-30-2014, 02:40 AM
  2. FS: LWB Seat Rails & Extra Bits
    By rennmark71 in forum For Sale: 911 Parts
    Last Post: 07-13-2011, 02:18 AM
  3. FS: extra tools for tool kits
    By RS-GT in forum For Sale: 911 Parts
    Last Post: 06-15-2010, 07:35 PM
  4. Extra A/C condenser/fan FREE
    By Schiefer in forum For Sale: 911 Parts
    Last Post: 09-16-2009, 05:28 AM
  5. FS : oilcooler
    By egbert in forum For Sale: 911 Parts
    Last Post: 02-23-2009, 06:14 AM
