Results 1 to 7 of 7
Thread: Recaro badge ; info needed
    Feb 2005
    Montreal, Canada
    Hi
    I found a pair of Recaro bucket seats, but the RECARO badges are gone after poorely recovering many years ago... I thing I have someone who can reproduce them, Does someone can post a photo of the badge but at a 90 degrees angle to have a straight look for sizing ? (instead of the angled shot I have)
    I will also like to have the exact dimensions of them (width x height x thickness) If someone have one uninstalled, I would also like to see how the hold to the seat cover ?
    If it work as I hope, I will offer them to all who can be interesting !
    Thanks !
    JD
    Hi JD, just to make you aware before you go to a lot of time, trouble and expense, it's my understanding that the Recaro buckets fitted to cars like the ST's, RS lightweight and RSR from the factory never came with the Recaro badge. The badge was on aftermarket seats supplied from outside stockists.
    It's my photo you used here from when I was trying to find another badge, I did get one in the end, so I will do the photo's and give you the dimensions you need tomorrow.
    Mike
    cheers, Mike
    Member#1664
    1972 911 S/RSR to Martini Prototype specification
    http://www.ddk-online.com/phpBB2/viewtopic.php?t=15294
    Feb 2011
    Northern VA
    JD,
    Did you end up reproducing these? I have an aftermarket Rallye 1 that could sure use one.
    Gene
    Senior Member uai's Avatar
    Jan 2011
    Horb a.N. Germany
    Feb 2011
    Northern VA
    Vielen Dank. Ich kann mich glücklich schätzen!
    JD - I could really use a set of these as well - if you are still looking at making them I can get you the dimensions and send them across to you.
    1972 911 Narrow-Body Group 4 Project - On The Road.
    Feb 2011
    Northern VA
    Ended up getting swooped on the ebay Recaro badges. Still looking for 1 (one)
    Thanks out there in Early S land,
    gene
  1. Need info on recaro buckets...
    By Porsche-RSR in forum General Info
    Last Post: 05-12-2009, 10:40 AM
  2. Input needed: Recaro seat badge
    By kenikh in forum General Info
    Last Post: 02-10-2009, 10:17 AM
  3. Weber 46 info needed
    By BURN-BROS in forum Technical Info
    Last Post: 06-11-2008, 06:10 PM
  4. engine info needed
    By wsh in forum Technical Info
    Last Post: 02-14-2005, 02:36 PM
  5. Revson 911 S Info needed
    By Rennman in forum General Info
    Last Post: 09-16-2004, 05:16 PM
