Results 1 to 7 of 7
Thread: Whats this contact?
    Whats this contact?
    I have this unused contact in my car, never thought about it untill a friend(Schiefer) asked what his was for. Its located to the rear of the electrical panel in the engine compartment. Look at the picture, its on the far left. What is it for? Rear wiper, rear fog, AC stuff? Cant find it in the elec. diagrams.
    Early 911S Registry #931
    1971 911 2.2T Coupe Tangerine
    Did you look at the wiring diagram for the sportomatic? I think that there may have been a relay for the sporto on the engine bay relay panel.
    Tom F.
    Long Beach, CA
    Apr 2003
    Portland, OR
    Hi John,
    Looking at page 206 of my Haynes, it is a relay for a single stage rear window defroster.
    The relay in front of it is the Start enrichment relay. The silver cylinder behind the relay is the RPM sensor.
    Who would have thought the Haynes actually had good info!
    Harry
    Member #789
    2009 MB C300
    Harry, thanks but I did not expain my selv well enough, the contact I was inquiring about is the one inside the red ring in the picture. It comes off the wire harnes behind the electirical panel. Harry, you are referring to the round black relays I presume?
    Ready for the Hunaudières manu72S's Avatar
    Nov 2004
    Hello from Le Mans
    There are two connectors like this. the other one is inside the electrical panel.
    So the one you refered to is used for sportomatic system. the second for 2nd stage rear defroster.
    hope this help
    Thanks Manu, now I just need to find out what this conector has to to with the sporto setup(I do not have a sporto, but understand that this is incorporated in all these cars as standard) The connector inside the electrical panel(for rear defroster) is similar but has space for 6 pins, se picture.
    Apr 2003
    Portland, OR
    Quote Originally Posted by Zithlord View Post
    John,
    Sorry for misunderstanding. Fortunately, those smarter than I figured it out. I did not see the connector in the back. And yes I am referring to the black relays.
    Harry
    Member #789
    2009 MB C300
  1. Whats your story?
    By super9064 in forum General Info
    Last Post: 03-23-2019, 07:11 AM
  2. whats gas to use?
    By ds58 in forum Technical Info
    Last Post: 11-21-2012, 10:02 AM
  3. Whats this part
    By joetiii in forum Technical Info
    Last Post: 04-09-2007, 12:57 PM
  4. Whats Going On in Monterey
    By boxster03 in forum General Info
    Last Post: 08-24-2005, 11:21 AM
  5. whats my car worth?
    By zmayne in forum General Info
    Last Post: 05-29-2004, 03:59 AM
