Results 1 to 8 of 8
Thread: battery drain traced to #2 fuse on '68...now what?
    Dec 2004
    SE Michigan
    On my '68, the battery goes dead after the car sits for 4-7 days or so. Don't know the age of the battery, but it looks relatively new. Have had no problems driving at night for 1 - 1 1/2 hours at a time. Headlights aren't dim, etc.
    Checked the current draw at each fuse location. The #2 fuse (cigarette lighter, interior lights, clock) showed 0.66 mA draw while all other fuse locations showed 0.0 - 0.1 mA (I interpret this as zero). When interior lights are on, the draw is around 0.77 mA.
    Based upon experience, what should I check next in order of likelihood? Clock? Prefer not to go through all of the circuits if someone has a feel for the the likely culprit.
    Bill G.
    EarlyS #718 | RGruppe #437
    pull the bulb on the interior light, it drains mine slowly...
    Bob Petitt
    1967 911S Coupe 307653S, my barn find - 55,000 miles Looking for engine #961269 and trans 901/02 #104337
    1971 911T Coupe 9111120264, my first 911 back in my garage
    1972 BMW 2002, my first car - 350,000 miles and counting
    1972 911T Coupe 9112100970, Sporto, parted it out..
    1983 BMW 320i, my everyday car - 138,000 miles and gutless
    2005 Subaru Outback, the daily driver - boring
    2006 Volvo XC90,
    Registry Membership #202
    Oct 2008
    Burford, ON, Canada
    Quote Originally Posted by 911scfanatic View Post
    The clock would be a likely culprit, but that is still very fast.
    Are you sure of the scale of your readings? 0.77 mA for the light seems awfully low, are you sure it isn't 0.77 A?
    Nov 2002
    Worshington State
    Eliminate the variables one by one - I agree with Dave and would recommend disconnecting the clock first.
    I purchased a clock in 'excellent condition' on ebay. Shortly thereafter, my battery was killed just a few days after not running the car (several times). Come to find out from Bernie, there is a mechanism (rewind?) which sometimes goes bad. It is designed to run periodically but when the mechanism goes bad, it runs perpetually and draws a significant enough current to kill the battery.
    The sick clock has now found a new location where all it draws down is my electric bill.
    Senior Member karlusmagnus's Avatar
    Aug 2005
    NY
    I think Allen and John are the same person operating under the guise of two respected individuals on the Board in an effort to flood the early 911 world with fake 7R wheels. How's that for a theory?
    Bill, looks like your speaking out against the forces of evil has resulted in their sending the gremlins to git ya Your efforts to stand tall against a flood of fake 7R wheels are making you a martyr. And draining your battery
    Sounds like the clock. I guess previous owner had same issue, and only solution was to buy new battery for resale.
    '72T Coupe - Sepia Brown
    Dec 2004
    SE Michigan
    Karl, if I don't fight evil, who will? The world is a little shy on super heroes nowadays.
    Everyone, thank you for your replies. I will continue work on this tomorrow with a suspicious eye on my clock.
    Bill G.
    Dec 2004
    SE Michigan
    Yes, I have been having problems with gremlins for some time. The other week I was tuning the carbs with the obligatory beer to help ensure a job well done. Anyway, I had the beer on the roof. I looked away for a moment, and the beer mysteriously fell off the roof and left a nice dent in the quarter trim. Fortunately, I had some cameras set up to catch the little SOB in his next act:
    Bill G.
    trim
    I have always wondered how I got the same dent on my chrome trim. Came that way from the previous owner. I guess he had the same "gremlin" in his garage.
    Olin - Member #1375
    1972 911T
    Original
    Options added
  1. Replies: 6
    Last Post: 01-12-2024, 07:58 AM
  2. Slow Battery Drain While Driving - Cause?
    By Ruby911 in forum Technical Info
    Last Post: 05-18-2013, 07:57 AM
  3. Chasing a battery drain
    By Max (SD) in forum Technical Info
    Last Post: 05-15-2012, 09:54 AM
  4. GPS-Traced On-Board Video
    By CurtEgerer in forum Off Topic
    Last Post: 06-13-2010, 11:22 PM
  5. Battery Drain
    By NV Stig in forum Technical Info
    Last Post: 01-22-2009, 01:39 PM
