I have a set of Hella 169's. One of the front trim pieces is cracked. Does anyone out there have a pair of trim pieces.... or even one in good shape?
Al Kosmal
the X-faktory
Current projects; 69-911.5
76S rat bastard---off to Germany
1970 914-4...off to Wisconsin
73 911X Cafe Racer...........(off to S.F.....now racing in Germany)
66 912 ...off to France
71E 9111200979 ( gone to Paris..then to Corsica)
77S (off to NY)
Early S #1240
RGruppe #669
www.x-faktory.com
You will have better luck welding it and re-chroming after a smooth polish.
Olin - Member #1375
1972 911T
Original
Options added
Al:
Let me know if you still need this part....I have some 169 parts in storage.
Bill
Al Kosmal
the X-faktory
77S (off to NY)
Early S #1240
RGruppe #669
www.x-faktory.com
Al:
Here's what I have:
2 Hella bodies
2 hooded front pieces
2 mounting brackets
4 screws
The front trim pieces both have some blistering on them - on both it's on the lower right side when facing the light. One is better than the other, but neither are going to win you any show points. From what I see, it looks like the bodies are stamped/plated brass, while the front pieces are zinc/pot metal pieces which is why they seem to corrode in the same places.
The bodies are both in pretty good shape - no dents, and the chrome plating is only surface-worn on the very bottom from road use, with some nickel plating showing through.
Two of the lens mounting screws are original and are in excellent condition, while the other 2 are not original.
Also included are 2 lenses, both amber but only one is a true 169 fog lens (nick on the inside), the other is "721" lens; both Hella; made in Germany & both have good rubber seals.
Bottom line: $36 for everything including shipping to Washington.
Bill,
That is a great deal. i will take it all. Please PM me and let me know your payment details/preference...paypal?
regards,
al
Al Kosmal
the X-faktory
77S (off to NY)
Early S #1240
RGruppe #669
www.x-faktory.com
