Results 1 to 10 of 11
Thread: Need heat exchanger nuts
    Could anyone tell me where I can get the hex nuts that are used to attach the heat exchangers to the engine. I believe they are M8 nuts requiring a 12 mm socket, not a 13mm socket. I can find hex nuts with a 13mm head but not a 12mm head. I'm installing a set of SSI's and need to use the wrench SSI provides, which is for a 12mm nut, to fasten the middle nut on the right HE, where there is no access hole, unlike an OEM HE.
    Thanks in advance for any tips.
    Oct 2005
    Minneapolis, MN
    Are you in the states?....if so, I'll send you some.....
    Aaron Hatz
    Flat Six, inc.
    www.flat6.com
    Follow us on Facebook
    www.facebook.com/flatsixinc
    Are you sure that you need 12mm accross the flats? I just went out to the garage and checked the SSI wrench I received with my SSI's about 15 years ago and it takes 13mm accross the flats. I also checked it with some 12mm nuts that I took off of a BMW and the SSI wrench definately takes 13mm.
    Or maybe SSI changed the wrench since the Pliestocene days when I got my first set of SSI's.
    M8's should be 13mm.
    Tom
    Early S Registry #235
    rgruppe #111
    I am pretty sure I have some 12mm m8 copper nuts. Both with flange and without. They cost me about 50 cents a piece from Wurth, I will be glad to help. Here is the link. https://shoponline.wurthusa.com/wurt...log/group.jsp/. I like the fact that you want to use the 12mm nuts... i am that way to. 12mm ATF nuts are used on the studs for Weber carbs, but the yellow zinc ones, not copper. Keep the faith, Bill
    Bill Woods
    S Registry #1005
    copper M8
    I get my 12mm ATF copper M8 nuts from J.C. Whitney, VW section. Copper is best
    Restoration newbie.
    Jun 2007
    San Francisco
    I bought copper flanged BMW exhaust nuts from Pelican Parts, part number
    11-62-1-711-954-M58 they were $0.50 each. Have not fitted them yet.
    andy
    67S in pieces
    EarlyS: 1358
    [SIGPIC][/SIGPIC]
    Thanks guys!!
    Thank you all for your help. Aaron at Flat Six offered to send me some. And I double-checked; my nuts are 12mm, not 13mm. I guess bigger is not always better.
    I pulled my old SSI-1 wrench out and it is 13mm. I have a bag of nuts from Stoddard that are 13mm.
    Here is a photograph which isn't the best resolution.
    Good luck,
    Tom
    rgruppe #111
    Mar 2006
    Louisville KY
    Either will work the 12mm or the 13mm. The plus side of using the 12mm it gives you a little more room to get a swivel socket in there to tighten down the exhaust. Specially if you don't have the SSI wrench tool.
    Just my .02 cents
    Tony Proasi
    52 split window coupe
  1. 914-6 heat exchanger
    By VintageExcellen in forum For Sale/Wanted: Other Porsche Cars and Parts
    Last Post: 10-10-2012, 11:55 AM
  2. FS Heat exchanger for 2.2 T
    By Frederic L in forum For Sale: 911 Parts
    Last Post: 01-23-2012, 01:17 PM
  3. Heat exchanger 101
    By beaker in forum Technical Info
    Last Post: 10-29-2009, 06:27 AM
  4. Are 69 heat exchanger nuts 12mm or 13mm?
    Last Post: 12-29-2005, 06:19 AM
