Results 1 to 2 of 2
Thread: Removal/installation door glass
    Hi:
    Time to remove the old scratched glass. Does anyone know of the proper way to remove and install the glass. I have the door panels off and it looks like the window frames must be removed also.
    Please help!
    RGruppe member 445
    Yes, the window frames must be removed, then you can unbolt window regulator so that you can move it fore and aft in the door to allow you to slide the window off of the regualtor arms. The window then comes out the top of the door, after you remove the "fuzzy" furring strips.
  1. Targa Rear Glass Installation
    By laketrash in forum Technical Info
    Last Post: 08-05-2022, 01:23 AM
  2. Glass Removal SWB Vent
    By 50/50 in forum Technical Info
    Last Post: 12-26-2013, 08:02 AM
  3. Front Vent Glass Window Removal?
    By TheBen in forum Technical Info
    Last Post: 11-16-2013, 03:37 PM
  4. Front and rear glass removal
    By cmcfaul in forum Technical Info
    Last Post: 06-21-2010, 07:28 AM
  5. VDO instrument glass removal
    By RS SIEG in forum Technical Info
    Last Post: 04-12-2003, 01:43 AM
