Results 1 to 10 of 13
Thread: Fuel tank question - 911E/911S vs. 911T
    hi all
    i was experiencing some fuel surge/power cutout in my 2.8RSR (MFI) engined 911ST rally car at the track today. started occurring when the needle was slightly above empty (low fuel warning light not on).
    before i start looking at swirl pots etc i though i would check if cars delivered with MFI had different tanks to those delivered with cars. (my car started life as a carb'd 70T)
    any ideas?
    Cheers, Ryan
    Founder and chief centre cap remover at : ZOLLHAUS / Design driven custom PORSCHE : https://zoll.haus
    Ryan,
    I believe all the 'standard' tank cars had the same tank.....
    However, I and others have had the same problem with our MFI cars when on the track side loading the cars with anything under 1/4 tank on board.....
    When I'm running at the track I try to keep my tank at least at 1/2 all day.
    I'd like to hear from others about if they've encountered this .....
    Cheers
    Jun 2005
    Perth WA
    Ryan,
    I had the same issue at Winton with slightly less than 1/4 tank, seems that if I keep it above that no issues at all. From memory was worse on right hand corners?
    Michael
    Michael
    thanks guys - looks like its time to look at a swirl pot
    (i can't bring myself to lug all that heavy fuel around!)
    Cheers, Ryan
    I have the later sc tank in my '71, and I relocated the fuel pump to the front as well. Big improvement.
    I can run the tank down to about 1/4 tank at the track now, while the old tank was a little under half before I'd get fuel starvation in left hand corners.
    Todd
    '71T 3.2 Spec 911 #806
    '69 BMW E9 Coupe
    So a 1971 911S would not have the swirl pot?
    Senior Member Grady Clay's Avatar
    Sep 2004
    Unincorporated Arapahoe County, Colorado, USA
    Only cars with CIS have a swirl pot.
    The "tank to find" is from a '73.5 CIS car as it uses a standard spare. From the topside it appears the same. From the bottom it has the obvious center screen filter.
    Best,
    Grady
    Thumbs up
    Live and learn........
    Thanks Grady...... Holiday cheers to you and yours...
    I love our message board......
    thanks grady.
    looks like i will be fitting a swirl pot to my existing tank (as i have just converted it to centre fill)
    Cheers, Ryan
    Sep 2004
    Ryan,
    You can salvage a swirl pot from any CIS fuel tank (I assume DME also). You might look for the latest one possible with both fuel fittings using threaded connections for safety.
    There are several good Pelican threads about swirl pots complete with diagrams and images of cut-apart tanks.
    Search this forum (Ely S) for a post of mine about center-fill safety. It is more about fuel cells but has exact application for your 911.
    Chuck, there isn't a day where I don't learn how much I don't know. The problem is that it seems to happen more often.
    Best,
    Grady
  1. 73 S - fuel tank question...
    By mac73s in forum Technical Info
    Last Post: 01-10-2014, 11:09 AM
  2. 120 liter fuel tank question
    By cscrogham in forum General Info
    Last Post: 08-04-2013, 02:35 AM
  3. WTB fuel tank for 1970 911T..so cal prefered
    By davewadd in forum For Sale: 911 Parts
    Last Post: 06-15-2012, 05:20 PM
  4. '73 Fuel Tank Question
    By kh911 in forum Technical Info
    Last Post: 05-18-2011, 04:54 AM
  5. 911E Camshafts for 2.0 911T question
    By zmayne in forum Technical Info
    Last Post: 04-25-2005, 07:41 AM
