Results 1 to 9 of 9
Thread: P 290, Door pin removal tool
    Senior Member red911's Avatar
    Sep 2005
    Rhode Island
    Hello fellow listers,
    The correct tool to remove the hinge pins is Porsche tool P 290. It is a nice tool, but $250 seems high for a one time use. Does anyone know of die that can fit on a dent puller that someone sells? I have tried the hammer and chisel thing and I get nervous about damaging the hinge.
    Thanks in advance, Tom
    Senior Member BBausser's Avatar
    Jul 2004
    Sutalle, Ga.
    Get a long punch. Have someone hold the door and move it about while you gently tap the punch. Don't hit the threshold on the downswing. Make sure the door stop is disconmnected first. The second pin comes out a lot easier because there is more play. Putting it back together is cake.
    Currently:
    67 3.6 Rocket "Silver"
    62 T6 Outlaw Coupe "ole Yellow"
    65 F100 Custom Cab Flairside Shortbed
    Gone but not forgotten in last 2 years:
    67S Concours King
    67 912 Vintage Racer
    68 912 Flipper
    83 911SC
    93 Mo30 968
    too many cars before that
    Early S Registry # 787
    R Gruppe # 551
    "its better to wear out then rust out"
    I've never been able to get them out without heating the hinge. Obviously this isn't an option unless the car is being restored.
    Tom F.
    '67 911S Slate Gray
    '92 964
    #736
    For reference....
    Peter Kane
    '72 911S Targa
    Another thing to note when installing the pins, they do not go in all the way. The section at the top of the pin with the splines is designers to stay exposed. This allows you to get the P290 tool around the top of the pin.
    Atlanta, GA
    Quote Originally Posted by BBausser View Post
    Bill, Which pin do you do first, top or bottom?
    Mark Erbesfield
    1973 911S #9113301282
    1957 356A #58648
    1982 Toyota Land Cruiser FJ40
    1977 Toyota Land Cruiser FJ40
    1979 MB 450SL "Dad's old car"
    2019 Cayenne "Wife's car"
    Merbesfield, there is NO good substitute for the factory tool. The long punch would work on a 356 door but not well on a 911, for example how do you get the long punch up from under the car and hit it with a hammer ? There is no hole in the thresh hold like on a 356. And it will take more than gentle blows to move the pins. Having said all that you can do a search of Snap-On and Mac tools and you will find that they have "universal" door pin tools, that, while no substitute for the factory tool, will at least give you a fighting chance, (although paint scratching will likely occur) I know because I bought these tools a hundred years ago when I needed to remove a door. They did work, but it also made me buy the factory tool for the next job!
    Nov 2008
    Finland
    Maybe I have been lucky but I haven't had any probs taking pins off or installing them without factory tool. Must be quicker though with factory tool.
    - Ville -
    1967 911 Slate Grey/red, fully restored + 66' "r-ish" hotrod project
    Atlanta, GA
    What is the cost of the factory tool?
    Mark Erbesfield
    1957 356A #58648
  1. Door hinge pin removal - need help with tool...
    By mac73s in forum Technical Info
    Last Post: 02-02-2014, 03:21 AM
  2. WTB: Door hinge pins and pin removal tool
    By Toffynose in forum For Sale: 911 Parts
    Last Post: 11-19-2013, 05:56 PM
  3. Help Please! Door Panel Removal
    By ahklein in forum Technical Info
    Last Post: 01-09-2012, 01:29 PM
  4. Removal of Interior Door Panels
    By daepp in forum General Info
    Last Post: 03-31-2008, 02:40 PM
  5. Hub Removal Tool?
    Last Post: 12-06-2005, 12:36 PM
