Results 1 to 10 of 11
Thread: WTB mfi space cam
    WTB mfi space cam
    Needing a good MFI space cam for 72 911E, #014 pump cam #54.
    Kevin
    May 2006
    CT
    Kevin
    I can supply a good '69E MFI pump space cam.
    Let me know
    Tom Butler
    Tom Butler
    1973 RSR Clone
    1970 911E
    914-6 GT Clone in Progress
    Tom, not sure if the 69 will work. Can you send me pics?
    Kevin
    I have a #45 space cam from an 010 pump. It's an E from a 2.2. Probably a 1971. Let me know if this helps.
    Chris
    2004 GT3 Carrara White with a few mods...
    2011 987.2 Spyder White, LWB's, 6 speed... Crazy Fun!!!
    R #208
    S #607
    A #76
    Thanks Chris, like I said if you can send pics I will compare. I believe the 2.0 and 2.2's are narrower.
    Kevin
    Jan 2006
    Naperville, IL
    I thought all space cams were unique (profiles) and those were matched the the engine's cams...
    Kevin,
    Did you happen to try the usual sources? Gus@ Pacific FI; Henry@Supertec?
    FWIW, I have an entire '72T MFI pump 015 that I will part with.
    -Andrew
    '72 911E
    '82 931, '92 968, '93 968
    S Reg #1074
    All displacements and T,E,S type combinations have unique space cam profiles (coded information in the contours).
    However, the earlier cars- 2.0 liter and (I think) 2.2 liter use a pointed stylus to follow the profile and actuate the rack metering rods. The later 2.4 and 2.7 (019) pumps use a ball-tipped stylus follower which requires a smoother, wider space cam. The early narrow cam for the pointed stylus cannot interchange with the later stylus pump.
    These are regulator assembly pieces, so you could change regulator sections.
    (Also, the 69 uses the 2 solenoids for cold start and fuel shut off, while the later use only the fuel shut off.)
    Yes, the 2.4's have the pointed ball type armature and I believe are wider than previous years. I already have a 2.4T pump(015) which I'm running on the car now till I get my E pump sorted out. I emailed Henry at Supertec and no response so I called and he's checking(I told him to check his paper weight for the correct part#) In the meantime still looking
    Kevin
    Still looking.
  1. FS: RS MFI Space Cam
    By Andy 74 in forum For Sale: 911 Parts
    Last Post: 10-14-2013, 02:44 PM
  2. RS space cam
    By Andy 74 in forum Technical Info
    Last Post: 10-26-2012, 02:38 PM
  3. WTB: 046 MFI Space Cam (2.2 S)
    Last Post: 12-10-2009, 03:54 PM
  4. FS Bosch NOS 2.0L S space cam for MFI
    By lisa_spyder in forum For Sale: 911 Parts
    Last Post: 03-22-2009, 09:17 PM
