Looking for front fender mounted cooler, jail bar type for a resto on my 73 RS.
Appreciate any leads.
AJ
AJ
If you cannot find an original cooler you can use an sc loop cooler, you have to cutoff the lines where they bend and silver solder on the 30mm fittings. It will look exactly the same as original. Ron
I must not be up on the newest jargon here, is the jail bar type what used to be called the the "loop" or "trombone" or are you using that term to identify what I call the "honeycomb" or tube and fin type. If its the loop cooler (like what would have been on a 73 RS) then I can help, if you mean the other, (honeycomb) then I can't. I just realized maybe you're referring to the 28 tube brass cooler, can't help there either.
He's looking for the one-year-only trombone with the short fittings. The 74-later trombones had the long pipe fittings.
-Marco
TLG Auto: Website
Thanks for the input.
Will most likely go with Ron's advice since the OEM ones are NLA.
Appreciate the offers and advice.
AJ
You have a PM.
-Marco
TLG Auto: Website
That's what I always knew as the "Jail bar" cooler.I just realized maybe you're referring to the 28 tube brass cooler, can't help there either.
Marco... I have some pictures for you if you want them. (thread hijack over)
Eric - Sandy, Utah
71 911
914-6/GT
914-6/ORV
87 944 Spec 1
Porsche Truck
62 Beetle
80 VW “Caddy” Pickup
72 R75/5 Toaster Tank
PMB Performance
We'll Make Your Calipers New Again
Love Us On Facebook
I have a 28 row in great shape if you want to go that route. PM me your email for detailed pictures.
Olin - Member #1375
1972 911T
Original
-117 Light Yellow -15x6 Fuchs (9120/M400) -S Appearance (M470) -5 Speed Transmission (9590)
Options added
-Houndstooth Sport Seats (M409) -Rear sway bar (9228)
-H4's -BTB Fog Lts (M429) -Amber TTG Driving Lts (9420/M432)
-380mm Steering Wheel -Becker Mexico -Roof Mounted Luggage/Ski Rack (9503)
-A/C (M559) -Rear Fog Lt (M571) -Rear Wiper (9290) -Wheel Trim (M426) -Footrest (9563)
So the 73 is shorter, thanks Marco, learn something new everyday here.
AJ,
I think this is the cooler you are looking for.
Brian
'71T
R Gruppe #299
