Page 2 of 3 FirstFirst 123 LastLast
Results 11 to 20 of 21
Thread: WTB: Front fender oil cooler OEM for 73
  1. #11
    yep
    Yes the cooler shown above is the jail bar, loop cooler or trombone cooler. The later sc cooler lines go up higher and then make a 90deg turn back so that both the cooler and the hard lines don't require any rubber hose fittings which are no longer available. i will have 2 of the fittings that get silver soldiered on to the SC cooler if you want to by them, i had a mchine shop make them. Thanks Ron
    Quote Originally Posted by fryardds View Post
    AJ,
    I think this is the cooler you are looking for.
  2. #12
    RS cooler "old thread" bump
    Is there a source for the fittings to silver solder to make a later trombone into an RS clone cooler? I would like to do this, as well as convert a later trombone into a hybrid cooler to be used in my 914-6 with a hot 2.4 S engine.
    Thanks in advance.
    registry# 1283
  3. #13
    Oct 2005
    wash dc/ los angeles ca
    I bought what is represented as an early style short loop RS / S cooler last year from DC auto parts selling for CarPoint ?
    I believe it's a reproduction but decent thanks oh and it wasn't cheap either , Bert
  4. #14
    Quote Originally Posted by budge96 View Post
    Thanks Bert. I see it on their website for $439. I think I am able to source the metric fittings locally, and am learning about silver soldering.
    BTW, are you pleased with the cooler? Work to your expectations?
    registry# 1283
  5. #15
    Jun 2012
    London, Ontario, Canada
    Porsche sells the trombone cooler and the flexible lines for the S/RS. Not cheap. I have this on my car and it is all very high quality and looks perfect.
    If you are trying to modify the later trombone which has longer 90 degree bends and hooks up directly to the oil lines, then you need M30x1.5 male fittings to solder to the later trombone after cutting it down. A hydraulic hose place in your area may have them. It's a common size, you just need a sweat connector.
    Ravi
    Early 911S Registry # 2395
  6. #16
    My 72 S is in storage. Can someone please measure, the distance from the top of the trombone to the top of the fittings?
    Thanks.
    registry# 1283
  7. #17
    Apr 2011
    N.Calif., south of SF
    Speedo
    which measurements are you asking for? Red or Blue?
    Haasman
    Registry #2489
    R Gruppe #722
    65 911 #302580
    70 914-6 #9140431874
    73 911s #9113300709
  8. #18
    Oct 2005
    S/RS trombone '73
    Quote Originally Posted by speedo View Post
    Thanks Speedo I actually have yet to install it it is at the shop and that detail is a bit far off at this point
    I may get a closer look at it though this month while out west and visiting shop and car , will update , Bert
  9. #19
    Quote Originally Posted by Haasman View Post
    Speedo
    Blue measurement...please.
    registry# 1283
  10. #20
    Apr 2011
    approximately 3 3/4"
    Haasman
    Registry #2489
    R Gruppe #722
    65 911 #302580
    73 911s #9113300709
  1. Replies: 1
    Last Post: 09-12-2013, 03:40 PM
  2. FS: 69-71 Front Fender Oil Cooler
    Last Post: 05-27-2011, 08:40 AM
  3. FS: 86 Carrera Front Fender Oil Cooler
    Last Post: 05-25-2011, 06:54 AM
  4. 72S Front Fender Oil Cooler
    By Longballa in forum For Sale: 911 Parts
    Last Post: 01-28-2009, 09:46 AM
  5. WTB - Early Front Fender Oil Cooler
    By sam71TargaS in forum For Sale: 911 Parts
    Last Post: 06-22-2007, 07:57 AM
