hinges: $25 per set
smuggler box cover: $25 as is, $65 finished bead blasting (pretty much ready for primer). This cover had some surface rust that I bead blasted clean to see if the metal is good. It is, some dimpling, but nothing some high build primer wouldn't fix. Rubber seal is nice. has no holes.
