Results 1 to 10 of 14
Thread: Wheel well, bumper & rocker caps- rivets?
    My 71E originally had the wheelwell trim and S rocker trim, etc. Luckily I found a set of wheelwell trim pieces, prior to their current high prices. It appears that these are installed using rivets. How about the bumper and rocker end caps... ? I'm getting close to that part of my resto. Any details that anyone can provide regarding the right installation hardware to use and where to source it will be appreciated.
    regards,
    al
    Al Kosmal
    the X-faktory
    Current projects; 69-911.5
    76S rat bastard---off to Germany
    1970 914-4...off to Wisconsin
    73 911X Cafe Racer...........(off to S.F.....now racing in Germany)
    66 912 ...off to France
    71E 9111200979 ( gone to Paris..then to Corsica)
    77S (off to NY)
    Early S #1240
    RGruppe #669
    www.x-faktory.com
    Rivets and screws`
    Al,the part numbers for the wheel well rivets and rocker end caps is 999.190.101.30.rocker panel and rocker end cap screws 900.145.043.00 both available from porsche or let me know if i can help.
    Thanks david
    Stoddard
    has the rivets for $.21 each I think. I was just searching last week for the same.
    Olin - Member #1375
    1972 911T
    Original
    Options added
    end cap trim
    on the 700 mile car rivets were used.
    look like pop type
    bob moglia
    '72 E sunroof coupe
    Bob/Olin, could one of you post a pic of the correct rivet? I will need to get some myselves.
    JOhn
    Early 911S Registry #931
    1971 911 2.2T Coupe Tangerine
    Don't have a pic, but here is the description Stoddard has
    07 999-190-101-30 Rivets for wheel well trim, 20 req'd. Fits 1969-1973. $0.26
    I was actually $.05 low on my estimate.
    John,
    These should be found in your local Porsche dealer, assuming it is close. I need to make an order in January, so let me know if I can be of help.
    Olin - Member #1375
    1972 911T
    Original
    Options added
    At the risk of advocating high heresy: I attached my wheel well trim strips with very small slotted machine screws and nylock nuts. That way I can remove the trim strips periodically for cleaning and corrosion control.
    John aka, the Capitalist Roader
    fellow traveller and party card carrying member #322
    73 Sporto S and 73.5 Targa in rehab
    700 mi car
    here's the thread,
    http://www.early911sregistry.org/for...ad.php?t=11193
    scroll down a few pictures, you'll see the rivets.
    look like plain old aluminum pop rivets to me.
    bob moglia
    '72 E sunroof coupe
    Thanks, forgot those pictures of the 700 mile had close ups of the rivets. I have those rivets already in my rivet "collection". Now I know which ones to use.
    Thanks for the info everybody. One step closer.
    regards,
    Al
    Al Kosmal
    the X-faktory
    77S (off to NY)
    Early S #1240
    RGruppe #669
    www.x-faktory.com
  1. WTB - Wide S Rocker Panel End Caps
    By lexatola in forum For Sale: 911 Parts
    Last Post: 03-01-2012, 06:25 PM
  2. FS: OEM '68S rocker decos w/ trim and end caps
    By kenikh in forum For Sale: 911 Parts
    Last Post: 07-04-2009, 06:46 AM
  3. WTT: NOS bumper end caps 69/71 for 65/66
    By preS in forum General Info
    Last Post: 05-12-2009, 09:27 AM
