Thread: Magnesium stack casting #s
    Does anyone have a reference that lists the casting #s for the MFI mag stacks from 69-71.
    I have two sets of "911" part # S stacks (the 911# designates them as 70-71) yet they have different casting #s.
    Any info would be appreciated.
    TIA
    1974 911"S" - Silver
    10 sec 67 VW
    Early "S" Registry #439
    2.2E #911 110 301 0R
    2.2S #911 110 303 1R
    I just looked at 4 of the S housings and they are the same.
    Matt
    Hmm,
    Looks like I may have a mixed up set on my shelf.
    The stacks are the 301 0R castings with 36mm" ports at the bottom, yet they were bolted to throttle bodies which measured 38mm at top and 36mm at where they meet the heads...which would be "S", correct?
    Thanks for your help
    10 sec 67 VW
    Found a good soource for the measurements
    http://forums.pelicanparts.com/showt...hrottle+bodies
    10 sec 67 VW
    Your throttle bodies are S spec. All the street S throttle bodies '69-'73, had the same 38mm top, and 36mm bottom that met the head. You have 2.2 E stacks on S throtle bodies. It is not uncommon at this point to find mismatched pieces. Usually you find S stacks put onto E throttle bodies though.
    Matt
  1. Does anybody knows this casting mark???
    By Olivier in forum Technical Info
    Last Post: 04-19-2016, 12:30 AM
  2. Casting date
    By tomlu in forum General Info
    Last Post: 01-08-2014, 07:49 AM
  3. 901/01 engine; 1964 casting, 900631
    By davidppp in forum For Sale: 911 Parts
    Last Post: 11-16-2009, 12:03 PM
  4. Fan Housing Casting Numbers
    By Neil '67 911S in forum Technical Info
    Last Post: 03-07-2008, 05:32 PM
  5. Heads for a ? - anyone know casting #s?
    By kenikh in forum Technical Info
    Last Post: 01-28-2006, 04:52 PM
