Results 1 to 8 of 8
Thread: Quick Battery Question
    Jun 2003
    Bend, Oregon
    I know there's been a lot of discussion here about batteries, but things change. It's time to replace the battery in my '67. I've always used Optimas in my 356's and I really like them - they last forever, they hold their charge and they don't leak. Is the Optima D51 Yellow Top a good choice for mounting up front in the original spot?
    What are the advantages of mounting an Odyssey PC680 or somesuch in the smuggler's box?
    Cheers,
    JohnA
    Sep 2006
    Maryland
    I use the Optima in my 356s also, great batteries. I don't have the measurements, but if there is a height issue the Optima can be mounted on its side, unlike conventional batteries.
    "What are the advantages of mounting an Odyssey PC680 or somesuch in the smuggler's box?"
    Its a racers trick, the boxed battery recess, blocks cooling air to the brakes, relocate the battery and remove the boxes.
    Rob Abbott
    Odyssey
    John,
    I have heard bad problems with Odyssey batteries not holding charge very well. Only have heard good things from Optima owners (you included).
    Olin - Member #1375
    1972 911T
    Original
    Options added
    One battery is not statistically valid BUT
    I have LOVED my Odyssey batteries and had no problems with them. I have had one as a spare I use for projects for two years, in and out of cars, and it works great. Frankly, I can't imagine them no holding a charge but I can't prove that they don't. Frankly, I suspect competitors may be spreading such rumors. They are spiral wound, very powerful (high amp-hours and high cranking current) and totally sealed.
    -Allen-
    Quote Originally Posted by jaudette3 View Post
    No, you need the red top.
    Quote Originally Posted by super9064 View Post
    No boxes on a SWB Rob
    I believe the yellow tops are deep cycle.
    Tom F.
    '67 911S Slate Gray
    '92 964
    #736
    Nov 2002
    Worshington State
    DVVK (a real first name in the sig line would be a nice courtesy) is absolutely correct. You do want the Optima Red Top.
    Happy Years Change!
    Optima storage charge?
    Can you, should you, charge these batteries over the winter with say a Battery Minder maintenance charger like you would a traditional battery?
    66 911
    67 911
    69 912
    71 911
    77 911 3.2 track
  1. Quick question on 72 T- Konis
    By Veronica87911 in forum General Info
    Last Post: 05-18-2013, 04:40 PM
  2. Quick fuchs question
    By pu911rsr in forum General Info
    Last Post: 06-18-2012, 06:02 PM
  3. Hi all........i have a quick poster question
    By Madeye in forum General Info
    Last Post: 04-01-2011, 02:53 PM
  4. Quick Interior Question
    By deck in forum General Info
    Last Post: 01-23-2011, 11:57 PM
