Results 1 to 10 of 18
Thread: Installing Wheel Arch Trim
    Jun 2003
    Bend, Oregon
    I just received a set of wheel arch trim that I intend to mount on my '67.
    I've always heard that the trim was available as an option starting in '69 or somesuch, but I'm told this trim came off of a '67 (and the source that told me is 100% reliable).
    Anyway, I'm not sure how they were mounted. I suspect screws were used as the holes in the trim pieces are recessed. But rivets could have also been used. Does anyone know?
    Cheers,
    JohnA
    M-426
    Some rivets have been used on my car
    Fred
    1970 911 2,2 S Coupé Albert Blau
    Jan 2003
    UK
    John - they were attached with rivets - part number 999.190.101.30.
    I can't remember if there was anything special about them but they're still listed by Stoddard's for $0.26 ea :
    http://www.stoddard.com/shop/shopdis...asp?Search=Yes
    I had always thought that they were introduced as an option for the '69 models.
    Andy
    Early 911S Reg #753
    R Gruppe #105
    John,
    My 71E originally came with the wheel arch trim, but by the time I bought it they were gone. However the remnants of pop rivets were still there. Aluminum pop rivets, I Think. I happened to have a pop rivet gun and assorted pop rivets. The standard aluminum 1/8" pop rivet appears to be a perfect fit. Anybody know what Stoddard is selling?
    regards,
    Al
    Al Kosmal
    the X-faktory
    Current projects; 69-911.5
    76S rat bastard---off to Germany
    1970 914-4...off to Wisconsin
    73 911X Cafe Racer...........(off to S.F.....now racing in Germany)
    66 912 ...off to France
    71E 9111200979 ( gone to Paris..then to Corsica)
    77S (off to NY)
    Early S #1240
    RGruppe #669
    www.x-faktory.com
    My original paint 73 still has the factory installed wheel arch trim, and what Al says is correct. I removed one piece to inspect the metal behind it, and I found that a 1/8" aluminum rivet from the hardware store matched the original rivets.
    Tom F.
    Long Beach, CA
    Aug 2007
    Phila Pa. area
    wheel arch
    I believe in doing whatever you want to your car, its yours, go to it. However I believe you will find that the trim needs to be combined with the wide, 3 to 4 inch rocker trim to make it look correct. The wide rocker trim and wheel arch trim started with the long wheelbase cars. But it is easy to put the arch trim and wide rocker trim on SWB cars and it looks like it belongs. I put both on my 1967S back in 1970 and never looked back.
    Jun 2003
    Bend, Oregon
    Quote Originally Posted by mike curnow View Post
    ...I believe you will find that the trim needs to be combined with the wide, 3 to 4 inch rocker trim to make it look correct. The wide rocker trim and wheel arch trim started with the long wheelbase cars. But it is easy to put the arch trim and wide rocker trim on SWB cars and it looks like it belongs. I put both on my 1967S back in 1970 and never looked back.
    Mike...
    After trial mounting the trim I think you're correct. Without the wide rocker trim the wheel arch trim doesn't end in a place that makes sense. Now I'm a little torn. I really like the look of the wheel arch trim, but the rocker trim is a major distinction between the SWB and the LWB. And I like respecting the essence of the original look of my cars. I have '67S rocker trim on there right now that took me forever to find, and I prefer to keep it.
    The originality is so confining. I thought I had gotten over it with my '60 Super 90 Roadster were every part was original (original original or NOS), a project that took 8 years to complete.
    Cheers,
    JohnA
    P.S. I completely trust the person who advised me that the set of trim I had came off of a '67. But I suspect the trim had been added at a later date. And I'll bet the later rocker trim was also on there,
    Quote Originally Posted by andyjboy View Post
    I found this link to work better. It's line item #7. Thanks for pointing out the part number!
    http://www.stoddard.com/shop/shopdis...=External+Trim
    Peter Kane
    '72 911S Targa
    Hi,
    The actual arch profile differs from SWB to LWB, the LWB cars have a flat outer edge on which these trims fit up to. I have a few sets of these trims in the work shop and will try offering them up to a 67 car today.
    Alan
    Jul 2006
    Switzerland
    Alan.
    just curious: How do you mount these on a 67S ? They dont had wide rocker panels as 68 911S and 68 911L did feature.
    Registry member No.773
  1. Wheel trim arch
    By MY911S in forum For Sale: 911 Parts
    Last Post: 12-21-2011, 06:22 PM
  2. Wheel arch trim FS
    By rvdv in forum For Sale: 911 Parts
    Last Post: 08-27-2010, 08:15 AM
  3. FS; wheel arch trim set
    By 9seriesguy in forum For Sale: 911 Parts
    Last Post: 02-19-2010, 09:44 AM
  4. Wheel arch trim set $375.00
    By Bobboloo in forum For Sale: 911 Parts
    Last Post: 01-06-2009, 12:36 PM
  5. Wheel arch trim/anodized fender trim S pkg
    By mrbeverlyhills in forum For Sale: 911 Parts
    Last Post: 03-18-2008, 07:55 PM
