Thread: 68 softie resto questions
    Is there supposed to be any kind of a seal between the fender flange and body? Second question, which side does the radio antenna go on? I've seen pics with the antenna on either side. I've also seen pics with the antenna more forward than others.
    1968 911S Soft Window Targa
    Softie in KS
    Manual antenna goes on LH side; electric antenna goes on RH side. Check your CoA to see which one your car was built with. Reason is that there is insufficient room on the LH side for the electric version.
    Early 911S Registry
    Looking for engine 960 168
    Looking for gear box 103 165
    In addition to the answer you got on the antennas, there is a seal strip between all of the fender mounting surfaces. Wurth sells the correct original style. You'll have to buy the roll which will be more than you'll need.
  1. LWB Softie questions
    By dporsche74 in forum General Info
    Last Post: 01-26-2011, 07:46 AM
  2. 68 Softie Hot Rod
    By Macroni in forum For Sale/Wanted: Early 911 Cars, 1965 - 1973
    Last Post: 01-02-2011, 11:55 AM
  3. 68S Softie
    By RMartin in forum General Info
    Last Post: 07-19-2009, 03:20 PM
  4. $95,000 67 Softie.
    Last Post: 08-04-2008, 09:20 AM
  5. FS 67S softie
    By EARLY911ZOO in forum For Sale/Wanted: Early 911 Cars, 1965 - 1973
    Last Post: 07-22-2008, 11:34 AM
