Results 1 to 9 of 9
Thread: Gas tank goodness
    Gas tank goodness
    Just installed my refurbed gas tank. I know I'm easily amused, but I really like it. This tank was in great shape, as is, so I didn't remove all of the factory coating, just at the seams and around the few scrapes etc. Those were ground down to bare metal and POR-15'd, then I re-coated the whole tank with Wurth Hi-build black, then Wurth Grey. The Grey was supposed to be the factory match, but it didn't match very well, in my opinion. Too much silver in it. I painted over with Hi-temp engine paint in Ford Grey. I'll go to purist hell, for sure, but I like the way it turned out. You decide.
    Al Kosmal
    the X-faktory
    Current projects; 69-911.5
    76S rat bastard---off to Germany
    1970 914-4...off to Wisconsin
    73 911X Cafe Racer...........(off to S.F.....now racing in Germany)
    66 912 ...off to France
    71E 9111200979 ( gone to Paris..then to Corsica)
    77S (off to NY)
    Early S #1240
    RGruppe #669
    www.x-faktory.com
    Looks great Al! When I did mine, it turned out a little to light grey, I did not like that....
    Early 911S Registry #931
    1971 911 2.2T Coupe Tangerine
    Senior Member Ringmeister's Avatar
    Feb 2007
    Looks good now don't scuff it with the spare.
    '73 T 2.7RS spec.
    John,
    I thought that the Wurth SKS turned out too light, as well. It also looked to have a bit of silver in it. It didn't look like the factory color, to me, and it was also too close to the body color. This is a shade ot two darker.
    Ringmeister,
    I've already had to touch up the scuffs that I introduced installing it. The 1st one is the hardest and then after a while I get used to it.
    regards,
    al
    Al Kosmal
    the X-faktory
    77S (off to NY)
    Early S #1240
    RGruppe #669
    www.x-faktory.com
    Al, it was impossible to get the grey Wurth in Norway, I had to settle with the black SKS ;-( I acid washed it after using a heat gun to get off the original undercoating. Filled a couple of pin sized holes with JB weld. Then sandblasted it, then rince in a industrial cleaner. Then POR-15, acid primer, epoxy primer, Wurth, and then grey paint.... I think the painter also missed on the structure of the SKS, crap...
    Next time, I will shoot it my selves.
    John,
    That looks great. Nothing nicer than newly finished and/or plated parts. It is amazing the amount of various cleaners, solvents, paints, plating and coating that we end up using on these projects. My garage is turning into a hazmat zone.
    regards,
    al
    Al Kosmal
    the X-faktory
    77S (off to NY)
    Early S #1240
    RGruppe #669
    www.x-faktory.com
    Well on the possitive side it will never rust, on the negative side my garage is also turning in to a chemical disaster...
    Gas tank goodness
    Al, don't worry about the 'purist hell' the tank looks great, so what if it's off a shade or so. What I ended up doing was to slice off a section of the painted undercoat and having a paint supply store match that color.
    Edmayo,
    That's a great idea! Next time for sure.
    Al
    Al Kosmal
    the X-faktory
    77S (off to NY)
    Early S #1240
    RGruppe #669
    www.x-faktory.com
  1. 240k / Skyline goodness
    By obrut in forum Other Car Cultures
    Last Post: 11-20-2013, 12:56 PM
  2. WTB: Plastic Windshield washer tank as a catch can/tank
    By Bavaria911 in forum For Sale: 911 Parts
    Last Post: 05-29-2013, 06:42 AM
  3. I love fresh parts (S bumper goodness)
    By Mark Wilson in forum General Info
    Last Post: 05-22-2013, 04:03 PM
  4. Replies: 1
    Last Post: 04-22-2010, 07:24 AM
  5. Plastic tank to trade for 100 liter steel tank
    Last Post: 04-12-2010, 09:13 AM
