Results 1 to 10 of 11
Thread: Dizzy Help
    Dizzy Help
    Hi all,
    I have a 2.2T motor that I am wanting to upgrade to "S" specs. I was told that I need S or E P/C's and dizzy. I found a dizzy that is part number 0 231 159 001 jfdr 6 and he thinks it is from an early euro S. Any idea if this is what I need and any idea of value? Thanks in advance. MArk
    1997 993 C4S, Not totally stock
    2015 GTI
    1991 E30 M3
    1970 911T, Lilly. Slate Gray 3.2ss PMO etc Sold!
    http://forums.pelicanparts.com/porsc...ect-lilly.html
    Early S Register Member #1386
    Since you don't seem to be obsessed with authenticity, why not just have your existing distributor recurved to S specs? Jerry Woods and many others will do it for you.
    jhtaylor
    santa barbara
    That is also a very good idea. I just want to do what is the most cost effective. As for authenticity, I don't want to do anything that isn't reversible since the car is numbers matching but I also want to make it fun to drive.
    2015 GTI
    1991 E30 M3
    Jan 2003
    UK
    0 231 159 001 is from a '67 911 (non-S)
    '67 S distributor = 159 002
    '69-'71 911E distributor = 159 006
    '69-'71 911S distributor = 159 007
    Andy
    Early 911S Reg #753
    R Gruppe #105
    Carrerax,
    If you are after "S" specs, you will require "S" pistons and cams, 2.2/2.4 -36mm heads, carbs/MFI, etc.
    Another configuration for you to consider is a 2.2 to 2.4 upgrade using E-cams, a 2.4 or 2.7 crank, carbs/MFI, 2.2 heads. This gives you a relatively high compression (10:1..ok on street gas w/o twin plugging) engine at 2.4L. These components will not be as pricy, as the S stuff and you will end up with a very good street rod motor. I built a 2.7 with E-cam, carbs, SSIs and JE 9.5:1 pistons. It was a lot of fun! i love the E-cams.
    Al Kosmal
    the X-faktory
    Current projects; 69-911.5
    76S rat bastard---off to Germany
    1970 914-4...off to Wisconsin
    73 911X Cafe Racer...........(off to S.F.....now racing in Germany)
    66 912 ...off to France
    71E 9111200979 ( gone to Paris..then to Corsica)
    77S (off to NY)
    Early S #1240
    RGruppe #669
    www.x-faktory.com
    P&Cs
    Just a comment on the P&Cs: I opted for the 2.7RS MFI ones because I found them to be cheaper than the S ones and I could run it on regular pump gas w/out twin plugging the heads($$$$). The significant difference other than capacity was that the RSs are nickasil, and the Ss were biral.
    Olin - Member #1375
    1972 911T
    Original
    Options added
    Dec 2008
    Woodland Hills, CA
    Quote Originally Posted by X-Faktory View Post
    Carrerax,
    But what Dizzy with the 2.4 E configuration?
    dizzy
    Use that 001 it has a nice full curve close to an E.
    Dec 2008
    Woodland Hills, CA
    How bout a 0-231-184-001 for that E configuration?
    Carrerax,
    Al, I would prefer to keep from splitting the case if possible. The motor is good and only has 59k original miles. Not to mention money. I just cant swing it. I have looked at the torgue curves and I do like the E ones a bit better for my application. I have had several peaky cars (E30 M3's) and although they are a blast to drive I would rather have a broader power band for this car. I also want to keep with Carbs. Ideally I want the best reasonably priced compromise. Im hoping just cams, pistons and maybe a dizzy or alter mine.
    Please continue to give me advice!! I need it.
    2015 GTI
    1991 E30 M3
  1. WTB: 2.2 E cams and dizzy
    By xpensivewino in forum For Sale: 911 Parts
    Last Post: 01-07-2013, 05:30 PM
  2. need a guy to rebuild my dizzy
    By Boulder Bob in forum Technical Info
    Last Post: 10-13-2010, 01:47 PM
  3. FS: 001 Dizzy, 6 Pin CDI, Fan Assembly
    By mrbmw2002 in forum For Sale: 911 Parts
    Last Post: 10-04-2010, 01:31 PM
  4. Re-Curve Dizzy
    Last Post: 05-20-2010, 06:06 AM
  5. WTB 2.2 E or S dizzy
    By 356robo in forum For Sale: 911 Parts
    Last Post: 04-17-2009, 01:52 PM
