Thread: Flat to 2000
    Junior Member
    Aug 2005
    Flat to 2000
    Is it just how 2.4S's are? I've been tweaking MFI pump around for ages: control rack and idle adjust, lean to rich, trying to get rapid response to the throttle when going from the get-go. It's just flat until say 1,500 rpm from 2,000 Afetr that the magic happens - its fairground stuff all the way to 7,000 +. Hold on to your hats!
    Rev up and slap the clutch in tends to result in shock and awe, especiaqlly in town, and can't be great for the clutch ayhoo.
    WHat's the consensus, is it just how the torque curve is?
    Garrett Dee
    Early 911S Registry # 848
    73 911S Targa
    I'd have to drive it to be sure, but they are pretty flat that low. About as inspiring as a 1.6L early '90s Miata actually!
    Kenik
    - 1969 911S
    - 1965/66 911
    - S Reg #760
    - RGruppe #389
    injectors
    Have you taken your injectors to have tested for cracking pressure and spray pattern? I suspect a poor spray pattern could be a problem and is probably more noticed at the lower rpm. I know the whole cam thing with Ss is not ideal at lower rpm, but I would venture to say that a brand new S did not drive the way you mentioned. Never have driven an S, just thought I would put my $0.02 in.
    I just recently tested mine and they were not atomizing the fuel like they are suppose to. I had them ultrasonically cleaned at the same time and they were not much better. I am living with them until I can cough up the $1000 it takes to buy new ones. I was doing a complete TB removal and re-calibration at the time, so it was not much effort to take the injectors out. At least they will be easy to remove the next time.
    Olin - Member #1375
    1972 911T
    Original
    Options added
    Flat to 2000
    Since I have two 2.4S's I can tell you that doesn't sound right, granted they don't pull great down low, but the 'on cam' effect starts at 4500 RPM, not 2000. There are a hundred possibilities that could cause this, but I would suggest you check the two most common faults I've found over the years; camshaft timing incorrect (once found E cams timed as S) and the length of the pump control rod. You've got to do this in an orderly fashion or you will just dig yourself a large hole. Suggest you get the "Check Measure Adjust " book on setting up MFI.
    Junior Member
    Aug 2005
    Thanks for your views. I actually had the injectors out last year (same thought process) and sent them to a Bosch Diesel Pump guy here in Ireland, who tested, declared they were 'wet'. sonicated, cleaned and retested. All he could say was afetrwards they all broke at the same pressure and were 'dry'. So I'm happy enough with them.
    The engine definitely comes on cam at 5000ish, and pulls progressively better from 2,000.
    I guess from your replies, that the flatness lower down is characteristic.
    Garrett Dee
    73 911S Targa
    Long shot, but is the distributor advancing properly?
    [SIGPIC][/SIGPIC]
    1972 911S Targa Paint to Sample Cocoa/Tan Leather (# 0836)
    Other Early:
    1974 Carrera SR Coupe (USA) GP White/Tan Shetland Cloth/Gold "Carrera" Stripes
    1971 911T Coupe Tangerine/Black (Destroyed in fire at Porsche Shop )
    1968 912 Coupe Irish Green/Black
    When In the "Dark" Side:
    1988 944 Turbo S Alpine White/Gray (1 of 481 Turbo S's Imported into USA)
    1991 928GT Guards Red/Spec Order Gray (1 of 85 GT's Imported into USA for 1991)
    Current Daily Driver: 2007 Shelby GT Mustang
  1. 69 911 coupe for $2000
    By 78mochasc in forum For Sale/Wanted: Early 911 Cars, 1965 - 1973
    Last Post: 10-18-2011, 04:02 AM
  2. FS: 67 targa - $2000 !
    By RS-GT in forum For Sale/Wanted: Early 911 Cars, 1965 - 1973
    Last Post: 08-04-2010, 09:08 AM
  3. FS/Feeler..Sparco Evo and Pro 2000..in NY
    By 70tangerine in forum For Sale: 911 Parts
    Last Post: 02-24-2009, 12:35 PM
  4. 2000 Boxster S - Portland
    By Herr Softie in forum For Sale/Wanted: Other Porsche Cars and Parts
    Last Post: 05-23-2008, 08:49 AM
  5. WTB 2000 - 2004 tip 997 convertable
    By mike walker in forum For Sale/Wanted: Other Porsche Cars and Parts
    Last Post: 07-17-2006, 11:53 AM
