Results 1 to 10 of 11
Thread: Help needed, what engine is this?
    Senior Member teveo's Avatar
    Jun 2008
    upper east side
    Some weeks ago I took out this tuned (revs easy to 7500 rpm) 2 liter from my 70S. I have found a correct 2.2S engine that I am in the middle of installing.
    Now, this 2 liter is a fun engine and I want to use it in a SWB 911 FIA rally car that I am projecting/collecting parts for.
    I took alot of pix today and maybe some can be of help to identify. Extra information, no type number or serial number. Never grinded off either. Stamped (june?)/67 to the left of the pulley.
    The intermediate shaft cover is listed at Frisinger as a "Historic racing part"
    http://www.freisinger-motorsport.de/...og=5&inquiry=1
    Any info and help to identify the engine is very welcome.
    Jun 2008
    upper east side
    11th picture, engine underside.. (max 10 pr post)
    Looks to me like the 67 case you mentioned with later chain boxes and SC chain housing covers (they have the threaded holes for installing the thermal switches), with a normal intermediate shaft end cover and turbo lower valve covers. By the way, the idle mixture adjustment screws and the idle air by-pass screws are reversed in their locations.
    Well lets take a lookie
    67 Case, you know that from the casting number.
    I/S cover looks like the one from a later car, the original is much larger cast iron
    cast iron distributor, what color is the nomenclature plate?
    later fan housing and fan with the coil studs on the housing. SWB is larger by 5mm and does not have coil studs
    later factory weber or Zenith manifolds with the black epoxy coating
    later chainboxes with carrera tensioners. Also someone has modified the tensioner/cam oil feed line into the case with a later fitting.
    turbo valve covers. you will find that the cam towers are off a later car too, because the lowers have 11 studs instead of 6-- only way to do that is to change the cam towers.
    Bosch CDI engine wire harness, good, also later car
    where the hell are the case numbers? Must be a factory replacement case.
    Tear it down! Can't WAIT to see what is inside
    Can you post pics of the following:
    underside of cylinders- cast iron v. nikasil v. biral and 80 vs 84 (I can tell the difference from a picture, 80 v. 84)
    underside of cylinder heads. this is hard to shoot around the heat exchangers, but we are looking for a number in an oval on the bottom cooling fin of the head-- this will tell what head castings you have
    nomenclature plate on distributor
    Jun 2008
    upper east side
    Thanks for all info, got some new pix of heads and case, case halves match and was stamped 971. .. 1973 heads ?
    Those are probably 74 heads judging by the late 73 date stamp- can you get a picture of the other side, the bottom? That is where the casting number is.
    Iron biral cylinders from 68/70 T-engine. Those are not the best cylinders. A bit of a surprice that they used those when building this engine. Very little oil and dirt around heads and case.
    Its a alu case, but a 71 date? Not sure its 71, because the alu ended in early 68. Was there any replacement cases or cases for racing 911 made in alu 70/71? Could the 71 stamp be something else than a date code?
    Early 911S Registry #931
    1971 911 2.2T Coupe Tangerine
    Jun 2008
    upper east side
    John, the 9 before the 71 is not visible, it should be 971 / case match number. Both sides same number which is good.
    I knew those cylinders where cast, i have to turn the engine another time (to take of the SSI headers) so I can use them on the S engine, will make some pix of the casting numbers then.
    Ok, I thought you meant 9/71 as in sept. 1971. I have not seen this type of number on my cases, but I have never had a early alu case..
    Oct 2008
    Burford, ON, Canada
    The 971 is simply a number stamped by the machine shop to identify matching case halves.
  1. Advice needed: Engine Pad – Yes or No?
    By uptheorg in forum General Info
    Last Post: 10-20-2012, 04:01 AM
  2. 67S Engine sheetmetal NEEDED
    By Rennman in forum For Sale: 911 Parts
    Last Post: 03-31-2011, 05:11 AM
  3. VIN and Engine # Help Needed
    By 69S-S/R in forum General Info
    Last Post: 05-06-2008, 08:40 PM
  4. Engine Gasket Kit 2.0 engine needed
    By Mudi in forum Technical Info
    Last Post: 07-18-2007, 08:03 AM
  5. engine info needed
    By wsh in forum Technical Info
    Last Post: 02-14-2005, 02:36 PM
