looks to be yellow under the red paint, so probably 72-73. Nice piece. $100 + shipping
Tru6 Restoration & Design
69S Targa, Velvet Green
73T Coupe, Gemini Blue
Early S Registry #1462
Would that be usable with a 67 with carbs ?
Does it cool the engine better than the earlier shroud ?
If so.
Dibs
Du must schwein haben
901/05 #305701
Bultaco Metralla 62 M8
1968 BMW R69S
Early911SReg #606
John, if you have carbs, I have a carb-specific shroud (no half-circle cutouts) from a 71.
My guess is you could use this with carbs, but not sure if it's optimal. I don't know if it cools better. it is a later design, so it very well may. hopefully someone who knows definitively will chime in.
Actually the first S's didn't have external coolers - mine doesn't. They started putting external coolers with the '69 S, but not before.
I did the shroud (later T shroud painted red) update on my '67S and the larger duct was good for a 30 degree drop in oil temps. I went from a oil temp of 210F to maybe 180F. But I also had a 120mm pulley installed. This might have to be changed back to the old 110mm one as the engine has problems getting over 140F when its in the early 60s outside. Based on my experience you don't need an external cooler.
__________________
This was from a thread John Cramer started on Pelican re mods to a 2.0 -
"Suggestions for a warmed over 2.0 901/05"
Any pics of that other shroud ?
What year/model is it from ?
901/05 #305701
1968 BMW R69S
Early911SReg #606
I believe this is from a 71T
Are you sure that black one isn't an earlier shroud ?
Don't the later ones have the channel that you see on the left side of the red one - which, if I am not mistaken is the reason they are cooler ?
901/05 #305701
1968 BMW R69S
Early911SReg #606
John, I think you are right as it looks exactly like the shroud off the 67 motor I am parting. It did come off a 71T I got years ago off eBay. That car was a mess-ended up parting it, so I am not surprised. Sorry to get your hopes up.
