Thread: Please edumacate me on steering wheels!!
    Hello - I'm confused about steering wheels.....one's on my '67S and the other came off of my '70 914-6. From what I know neither is original to the particular car it came to me on.
    The wheel on the '67S was presented to me as an original, but NOS, configuration wheel. From what I understand this wheel should be 400mm in diameter (measured from the center of the rim across to the center of the rim on the other side??) In fact, when measured this way, it is 400mm across.
    The hub of the wheel from the 914-6 is stamped "911 347 082 00" with a 1 73 (date code?) and a triangle with "VDM" inside. The hub and wheel are still riveted together.
    Searching this site for 911.347.082.00 turned up several posts identifying it as a 400mm wheel. However, this wheel (measured in the same way described above) is 380mm across.
    Is 911 347 082 00 a 400mm or 380mm wheel? Is there a reason someone might go to the trouble of switching a hub and wheel, riveting the assembly back together, painting etc. to try to make all appear original?
    What am I missing? .....or can anyone help explain what I have?? ....is one a fake? ....am I measuring wrong?
    TIA,
    Bob S.
    Bob Schaefer
    ‘67 911S Canary/Lemon yellow, sunroof coupe produced w/100L tank. Until determined otherwise, 306943S appears to be 1 of 1, and among the earliest 911’s with a 100L tank. The 911’s initial participation in a competitive event, the 1965 Monte Carlo Rally, was fitted with a 100L tank (#300055). Seeking additional info on earliest 100L tank fitments to 911’s.
    ‘70 914/6 (2.7l RS spec engine, but searching for 6404915 original)
    Measuring wheels
    I have one right in front of me. A 380mm wheel is appo. 380mm from the outside of the rim to the opposite outside. Ditto measuring them, more or less, other wheels.
    -Allen-
    Steering Wheel Measurement
    Thanks Allen. I rechecked, and the 911 347 082 00 wheel is 400mm outside-to-outside.
    So is a correct, original '67S wheel 420mm outside-to-outside?
    Bob....
    P.S./Edit:
    Allen - I think I've answered my own question by searching for '420mm'.....and find that is the correct '67S diameter.
    Bob Schaefer
    I believe that the 914/6 wheel is slightly smaller.
    I remember the hot setup in the mid seventies was to replace the stock 911 wheel with the one from the 914/6.
    It was smaller and felt better, but still looked stock.
    Of course, the other hot setup was the Momo Prototipo
    [SIGPIC][/SIGPIC]
    1972 911S Targa Paint to Sample Cocoa/Tan Leather (# 0836)
    Other Early:
    1974 Carrera SR Coupe (USA) GP White/Tan Shetland Cloth/Gold "Carrera" Stripes
    1971 911T Coupe Tangerine/Black (Destroyed in fire at Porsche Shop )
    1968 912 Coupe Irish Green/Black
    When In the "Dark" Side:
    1988 944 Turbo S Alpine White/Gray (1 of 481 Turbo S's Imported into USA)
    1991 928GT Guards Red/Spec Order Gray (1 of 85 GT's Imported into USA for 1991)
    Current Daily Driver: 2007 Shelby GT Mustang
    Jan 2003
    UK
    Allen - as a 'generalisation' :
    '65-'68 swb models had a 420mm diameter wheel
    '69-'73 lwb models had a 400mm diameter wheel as std*
    All 914/4 & 914/6 models had a 380mm diameter wheel
    *2.7 Carrera RS models had a 380mm diameter wheel as std
    S models (both swb & lwb) came with a leather rim wheel as standard - optional on other models.
    Andy
    Early 911S Reg #753
    R Gruppe #105
  1. 914 steering wheels
    By mepstein in forum General Info
    Last Post: 08-15-2013, 04:40 AM
  2. Steering wheels
    Last Post: 02-03-2013, 06:28 AM
  3. 911/356 steering wheels
    By 911s55 in forum Technical Info
    Last Post: 04-14-2008, 09:26 PM
  4. FS: Steering wheels
    By 70SATMan in forum For Sale: 911 Parts
    Last Post: 10-24-2006, 05:05 PM
  5. STEERING WHEELS- T vs S
    By MAPC in forum Technical Info
    Last Post: 04-05-2005, 07:46 AM
