Thread: 67 washer pump location
    old softie67S
    Feb 2007
    Sanibel Fl
    Could someone post an image of a washer pump mounted in the correct factory location. Is there a bracket for mounting?
    thanks
    Tom
    Tom
    67S soft rear window
    60 356 Cab
    70 914-6 3.2 short stroke twin plug
    05 Audi S4 Cabrio (commuter)
    05 Audi Alroad (family driver)
    Aprilia SR 50R (Sanibel scoot)
    1967 Washer pump location
    Thanks to Alois Ruf for this photo of the correct location.
    It seems 1967 had the tie wraps and sometime in the early 1968 run it had the four screws holding the pump to the stand off bracket. See the Parts manual illustration 8/1, item 37. Shortly into the 1968 model it moved up onto the vertical panel next to the revised washer bottle (with the neck thru the latch panel).
    HTH.
    Bob
    Early S Reg #370
    Relaxed Rich Lambert's Avatar
    Jun 2007
    Lake Stevens, WA
    Here's a picture of the pump bracket on my '66. I think it's the same set-up.
    Rich
    1966 911 #303872
    ES#1197
    RG#478
    old softie67S
    Feb 2007
    Sanibel Fl
    Thanks guys, appreciate the help
    Ok, I do not have one of those. Thanks for the image. I will slide over to parts wanted and try to find one.
    thanks again. tom
    Tom
    60 356 Cab
  1. 1971 - location of fuel pump/build date question
    By Sean F in forum General Info
    Last Post: 10-17-2013, 07:48 AM
  2. Picture of window washer pump metal sheet and location
    By Mdezeeuw in forum Technical Info
    Last Post: 08-27-2013, 08:53 AM
  3. 1968 911 Normal fuel pump location
    By JT912 in forum Technical Info
    Last Post: 01-21-2013, 10:13 PM
  4. Fuel pump location?
    By SteveD in forum General Info
    Last Post: 07-25-2009, 09:43 AM
  5. 67 washer pump
    By tomkirkcis in forum General Info
    Last Post: 05-30-2007, 12:59 PM
