Does anyone know where this tank can be purchased?
Stu
Stu
Stu, that is a washer bottle from a '66 or '67 911. Try Hershey swap meet.
There was another bottle I've seen in the 72 ST's , that differs from the one pictured above. It was also used in the 935's. (NOT the 72/73 washer bottle; its does not fit correctly with the oil tank breather hoses that the 72 chassis has)
Any leads on that one?
Member #755
Conda Green 70 911S
70 black 914-6 3.2
70 911 "Speedster" project
"74 IROC" tribute Jade Green RSR
Stu, the factory race cars used the early 911 washer bottle, it fits really well.
Here's a 'werks' engine bay with one fitted, and my recreation using one. As my car's a 72 I've swopped the oil pipes over so as the breather goes straight into the bottle.
cheers, Mike
Member#1664
1972 911 S/RSR to Martini Prototype specification
http://www.ddk-online.com/phpBB2/viewtopic.php?t=15294
Stu:
I used a brake reservoir overflow container from the 72/73 cars because it fits better (I think) than the washer bottles. It has a notch that matches the oil console quite nicely. I ran the breather hose like Mike did straight into the side. It has a breather opening on the back side (but higher up) similar to the one I plugged on the front, and has slightly more capacity than the washer bottle.
I like to think that a clever privateer from the day would have used this tank, as they seemed to have used many different types over the years.
I have both the early type and 72 type, but for now I am sticking with this one.
Gib Bosworth
EarlySReg 434
R Gruppe 17
Gib,
I think you mean 'fuel' vapor reservoir bud........
Cheers
Chuck:
Yes, you would be right...I have just stripped them out of a couple of cars not really noticing where they were connected. I guess it would take all the brake fluid and then some to fill one of these up. Weren't they only used in 72/73?
Gib Bosworth
EarlySReg 434
R Gruppe 17
In case it helps: thats a 1968-1973 washer bottle which available new from Porsche.
Alan
