Thread: Fuchs fitment from part number?
    I am looking at a set of 15X7 fuchs for my narrow body 73.
    The part number is 911361020 they look in the picture like they should be an excellent fit - is anyone using a similiar rim who could comment? May be post a photo.
    Also how can you tell the date of manufacture?
    912->911 conversion
    Nov 2004
    Calgary, Alberta, Canada
    The part # 911 361 020 is not definitive enough to find which wheel it is. There are two digits that should come after that. 7 x 15 should be 911 351 020 41. The 16" Fuchs have the same 911 361 020 part # with differing trailing identifiers (e.g. 44 is a 7 x 16 wheel).
    At any rate, yes that wheel will fit on your 73 with judicious tire selection. I think 205/55/15 is the biggest you can realistically fit, although I believe some have fit 225/50/15?? Rolling your fender lips will help the fit, but IIRC the issue is rubbing on the fender and burning your paint when the suspension is compressed.
    I have 15x7 on all corners of my 1969 without issues.
    Keith Adams
    Early 911S Registry #906 | PCA member IG: @912R
    1969 Blutorange 912R - 912 to 911 conversion
    1969 Mercedes 280 SE (W111) Coupe
    Apparently they end in 41 which should be correct for 15s.
    I currently have repo Fuchs on the car in 15X7 with 205-60s and they aren't showing any signs of rubbing. I believe the offset of real Fuchs gives better clearance.
  1. FS: (4) Fuchs 6x15 Part Number 901.361.012.06
    By Varooom in forum For Sale: 911 Parts
    Last Post: 09-08-2013, 11:15 AM
  2. Fuchs part number & value question - 8 & 9 x 15
    By geshaghi in forum General Info
    Last Post: 01-16-2013, 09:33 AM
  3. WTB the following part number fuchs 2 of each
    By vramani in forum For Sale: 911 Parts
    Last Post: 09-25-2011, 07:59 AM
  4. Fuchs part number
    By Francois Duval in forum Technical Info
    Last Post: 08-29-2011, 03:14 PM
  5. Part number for 4.5 x 15 Fuchs
    By hdavis in forum General Info
    Last Post: 07-14-2008, 01:19 PM
