Thread: HELP: oil tank leak
    Question HELP: oil tank leak
    i've been working om a '67 911 and i have found that the oil tank leaks. My questions are: hows the best way to fix the tank, or are there any aftermarket replacement options, or can i coat the outside of the tank with an epoxy, ect. please reply, thanks!
    I'm sure there's a few various methods but mine was brazed up carefully when I found oil spew constantly on the garage floor. There's a few threads around here on the subject.
    Paul Schooley
    S Reg #863
    R Gruppe #330
    Senior Member Dezzmo's Avatar
    Nov 2006
    Rhode Island
    Where is it leaking from? I noticed that I had a small leak on my oil tank but it was a bad gasket for the oil level sending unit.
    Could you post some pics so we could see it?
    We love pics
    Tim G
    Early S Reg #1017
    RGruppe #663
    73 911T 3.2
    00 Ducati 996 Track Rat
    01 Ducati S4 Monster
    Member 1488 MrJTP2001's Avatar
    Nov 2008
    Denver area
    You might just let a radiator shop take a look at it. They can do great work on tanks of all kinds.
    Thanks Guys, I'll look into those options and i"ll let you know.
  1. Gas leak.
    By r14 in forum Technical Info
    Last Post: 09-26-2012, 10:45 AM
  2. Oil Leak Help
    By pacarguy in forum Technical Info
    Last Post: 07-26-2008, 07:30 AM
  3. Oil leak
    Last Post: 12-02-2006, 02:21 PM
  4. Gas tank leak
    By 72911E in forum Technical Info
    Last Post: 10-27-2006, 08:11 PM
  5. Oil Leak
    By 911quest in forum Technical Info
    Last Post: 07-08-2006, 01:19 PM
