Searching for an older plastic inner door handle that came on 73 RS lightweights.
The new repo ones are matte black and rather flimsy.
Original ones were more of a smooth gloss and a bit more stout.
Appreciate any leads.
AJ
AJ
They were originaly from Fiat 500
Sierra madre has NOS RS door handles
73 RS 1189
81 924 Carrera GTS
69S 2L HSR
70 914/6 2.5 L HSR
2008 GT 3 RS
78 512 BB, 2000 550 Maranello, 85 308 GTSi
63 AC V8 prototype
63 fuelie vette
62 e type roadster
32 Duece lowboy hot rod ex Sqeek Bell
If it's not a real lightweight RS, why not consider a modern recreation of the notoriously weak original Fiat plastic gibblets. Have you seen WEVO's new forged aluminum handles, available in three finishes. Clear anodized, black anodized and unfinished ( which you can beadblast or polish. They look quite close to the original bits, but will last forever.
You can see them here: http://www.wevo.com/WevoContact.htm
JZG
Thanks all, the Sierra Madre ones are definately repo and it needs to be OEM as it will go in a real RS.
Edmond Harris sells them, but the cost is as much as an RS!
The search goes on.
AJ
Yes, in the past couple of years it has become increasingly difficult to find the correct original (Fiat) handles - as you say, the repro ones are inferior quality with a more 'satin' finish to the plastic & they don't swivel smoothly either.
Andy
Early 911S Reg #753
R Gruppe #105
Hayden Burvill (WEVO) is making an exquisite billetted aluminum handle that replaces the original. Not repro, just better.
356 Reg #16227
Early S Reg #700
R Gruppe #340
73 RS 1189
81 924 Carrera GTS
69S 2L HSR
70 914/6 2.5 L HSR
2008 GT 3 RS
63 AC V8 prototype
63 fuelie vette
62 e type roadster
