Thread: correct rev limiting rotor
    My 2.2 T engine has been modified with:
    Original T crank
    S pistons & cylinders
    mildly ported T heads
    E cam
    What would be a suitable rev limiting rotor? 6800, 7000, or what?
    Thanks in advance,
    Robo
    356Robo
    64 C Coupe #218448(sold)
    70T Targa #9110110416(sold)
    Jan 2006
    Naperville, IL
    I would go with an "E" rotor set @7100; The only item on your build that would scare me at a 7100 limit would be the non-counter weighted "T" crank.
    What distributor curve?
    If you are still making reliable power in that range then use it...
    Of course use my advise at your own risk.
    -Andrew
    '72 911E
    '82 931, '92 968, '93 968
    S Reg #1074
    A dyno run would be nice to test the baseline of the engine. No need flogging it past it's best power production just for the sake of it.
    Lot's of things will go past redline but are they still making power? Stay in the fattest areas of the torque/hp curve and you'll be quick.
    Tom
    Early S Registry #235
    rgruppe #111
    Thanks Andrew,
    I've not yet checked the dist curve. That's on my list of things to do to fully sort out the engine. Do you have any info on what curve would be best?
    Robo
    356Robo
    Another piece of info: the valve springs are listed as "AASE". Can someone please tell me about AASE springs.
    Robo
    356Robo
  1. FS: New 930 Caliper/Rotor Set Up
    By s2guy in forum For Sale: 911 Parts
    Last Post: 03-22-2012, 03:18 PM
  2. FS: Rotor Hats
    Last Post: 10-27-2009, 02:00 PM
  3. Replies: 6
    Last Post: 11-04-2008, 10:18 AM
  4. NOS 911R/906 Rotor Arm
    By Schläfer in forum For Sale: 911 Parts
    Last Post: 09-01-2008, 12:20 PM
  5. 6500 Rev Limiting Rotor does not limit...
    By jcarpio in forum Technical Info
    Last Post: 02-11-2008, 03:54 PM
