67S, trying to remove the black metal supports for the seat tracks....question is, what size/type tool is needed?? I tried a 12 point, an allen, a doppelgangen boltzengetzen...and no luck. Brian
Brian
S Reg #1032
If I understand correctly what it is you're trying to do, it should be a 5mm allen head. Maybe yours are rounded out.
Thanks. Yes, it is (or in the case of three of them, was) 5mm allen. Now for the easy-out. Brian
Brian
S Reg #1032
With the seat removed you may even want to try using a set of Vise-Grips.
I used a drill to get the heads off, then some WD40, and they came out with a plier. You can also cut a slot in them for a screwdriver.
Early 911S Registry #931
1971 911 2.2T Coupe Tangerine
If the allen heads are not too far gone, go to Sears and get a hand held impact wrench; the one that you hit with a hammer while you twist the barrel counter clock wise. It's the only tool I use to remove Allen head bolts- especially 6 mm x1 seat rail bolts. You might have to use an extension and/or half inch to 3/8 inch adaptor to make it work. Contolled violence is sometimes the answer.
73S Coupe with sporto and 73.5 Targa in rehab
If you need a few of these bolts to replace yours you had to destroy, PM me. I've collected a few of these over the years, happy to donate some to a worthy restoration cause.
1968 Porsche 911 #11830133 (2009- 2012)
1968 Porsche 911T #11820522 (1997-2007)
Registry Member #1536
Hagerty Insurance Guy
Missing my Porsche. Need to find another SWB project!
Current cars:
1918 Willys-Overland Model 90BT
1966 Sunbeam Tiger Mk1a
1977 Chevrolet Suburban C20 "Trailering Special"
1983 Ferrari 308 GTS Quattrovalvole
1992 RHD Toyota Century
PM sent, and thank you very much! Brian
Brian
S Reg #1032
