Results 1 to 10 of 12
Thread: WTB - MFI Pump Support Rod
    See below.....(pic courtesy of Armando)
    Thanks in advance guys..
    Stu
    Stu:
    How does that mount into the case with that long hex shaped end? Maybe we will have to start fabricating these also.
    I still can't really figure out why the factory used them. Those pumps were bolted down with 4 -10 mm bolts...doesn't seem they would be concerned about movement. Maybe the pumps occasionally pulled a stud (bolt) out of the case with the race engines because of their vibrating mass, but the only significant force acting on them was the belt on the back.
    Gib Bosworth
    EarlySReg 434
    R Gruppe 17
    What was the application? I have never seen one of these before. I thought Stu was referring to the hollow rod that supports the pump mount plate...
    Kenik
    - 1969 911S
    - 1965/66 911
    - S Reg #760
    - RGruppe #389
    Application began with the inception of the 2.5.
    Pix below is with a later config. Just for illustration purposes.
    Ooh, more jewelry! I might have to fabricate one of those...
    Kenik
    - 1969 911S
    - 1965/66 911
    - S Reg #760
    - RGruppe #389
    Question
    Could this contraption be just the best way to rig a simple torque-over limiter, like we've seen on some race V8's .......
    Quote Originally Posted by kenikh View Post
    You disappoint me, Kenik. It appears you haven't been doing your homework.
    -Marco
    TLG Auto: Website
    Chuck, please explain to those of us who are not V8 guys, what a 'torque-over limiter' is.
    Maybe the fuction is to be able to adjust tension on the cam belt before the nuts are tightened on the studs from the mounting base. Or, it could be a vibration damping brace.
    The 2.14 turbo engine used 2 braces, one at each end. The pump had to be relocated to the opposite side because of the horizontal cooling fan.
    Gib Bosworth
    EarlySReg 434
    R Gruppe 17
    My mistake.......
    Thought I was a convenient way to limit the motion of the engine from the chassis....... now I see the fixture is from pump to engine....
    Great photo Gib !!
    Quote Originally Posted by letsrollbabe View Post
    Stu:
    Here's a couple of pics showing the mounting on a 2.8 and a 908 - attachment point is on top of the case, to the right of the MFI oil feed banjo fitting. (908 pump support rod appears to be longer than the 911)
  1. Fuel pump support 1968
    By egbert in forum For Sale: 911 Parts
    Last Post: 10-04-2011, 09:58 PM
  2. Need support buying a 911 in NJ
    By mcampuzano in forum New York
    Last Post: 08-12-2011, 07:23 AM
  3. Need support buying a 911 in NJ
    By mcampuzano in forum ErsteGruppe
    Last Post: 08-04-2011, 06:32 AM
  4. Replies: 10
    Last Post: 08-13-2009, 02:48 PM
  5. Rs hood support diy
    By super9064 in forum Technical Info
    Last Post: 04-04-2009, 06:33 AM
