Results 1 to 10 of 12
Thread: Replacing t-bars; stay stock or bump?
    Found my front t-bars have been rubbing due to bushing 'cold flow' so need to replace them.
    Car has f/r sways already (factory stuff) and is used for fun weekends, auto-x and maybe the occasional DE. Would also like to do some hillclimbs in the next year or two as well if i can pass tech w/o a cage.
    I'm pretty happy with the handling of the car as it sits and DO NOT want a bouncy, rough ride. Bushings will be replaced with rubber (front and rear).
    Seems a lot of people do the 21/26 setup but this seems like a BIG increase over stock. It'd be nice to find a cheap used stock setup from either an early car or maybe an SC (just a touch stiffer in the rear right?).
    Thoughts on this?
    Erik
    Early S # 1107
    All my german equipment is either busted or sold...sigh....in the market for a decent non-sunroof tub!!!!!!! Help me get back to autocrossing!!!
    Thinking a bit more about this and what i would like is a car that is predictable and safe on back roads (and the odd track day) but can turn a good autox time.
    Maybe stock t-bars but switch to an adjustable rear sway? Tighten up for autox and loosen for street/track?
    Or do that AND 21/26?
    I'm not excited about the look nor cost of an adjustable rear sway but it seems like a good answer.
    Erik
    Early S # 1107
    21's and 26's give a very comfortable ride, but more controlled than stock. For reference purposes, I have hollow 22's and 30's in my '69 the ride is still quite acceptabel for the street (my finacee agrees as well). I definitely do not feel 21's and 26's compromise a comfortable ride.
    Brooke
    1969 911 ST w/ 2.8SS
    1973 911 RS tribute with 3.3 turbo
    1970 914-6 w/ 2.2S (sold)
    1972 BMW M2 (sold)
    R Gruppe #338
    S Reg # 855
    I just replaced my stock t-bars on my 69T' with 21 & 29 hollow bars. Im still running a 13mm front sway bar & no rear bar. My plan is to go to a bigger front sway bar and matching rear when funds allow.
    I did a track day yesterday and it felt like a different car , with a lot less body roll and much better turn in and predictability. No more "wheels up". I cant wait to get the sway bars on.
    I cant notice any real difference in ride quality.
    Matt Hart
    matthartcreative@instagram
    RHD 914
    1980 911SC (sold)
    69' T (sold)
    Early 911s reg # 994
    Feb 2003
    Los Angeles
    I have 21/26 torsion bars on my 1970 911T with factory 18 mm F/R sway bars. The ride quality has not suffered for a street car. It is firmer and more controlled, but not rough and noisy. I think you will like 21/26 torsion bars. Don't go too stiff on the shocks.
    The rubber suspension bushings are key.
    Good luck.
    Bert Jayasekera
    1970 911T - Tangerine Orange
    Early 911S Registry #494
    R Gruppe #167
    would 19/26 throw my balance off?
    no doubt it would be a nice ax combo and make the car easier to rotate but how would this combo be in fast sweepers?
    car is stock flared and will have 205/60's for street and 205/50's for track use.
    Erik
    Early S # 1107
    My 74 had the stock t bars, 19mm f and 23 mm rear. This set up yields rears which are about 2.15X as stiff as the fronts if my math is right (23/19 raised to the 4th power.) I like less understeer than that delivers. Lots of people run 22/29, which yields a rear bar that is 3X as stiff as the front and much less understeer. 19/26 would give rear bars 3.5X as stiff as the fronts, certainly not crazy and probably fine if you like some oversteer and have light hands.
    jhtaylor
    santa barbara
    22/28, Bilstein sports up front, Rallye in the back. Try that and see if you like it-- or go custom valved bilstein.
    That was my old race setup before I went to 23/31. Even 23/31 is not enough for race purposes.
    For the street 22/28 was firm but not rock hard. 23/31 is rock hard.
    Man seems like everybody is looking for 21's!
    Located 22/28's for sale but not dirt cheap. Maybe 21/27 would be a good compromise...
    Erik
    Early S # 1107
    Apr 2003
    Portland, OR
    You can always follow Steve Weiner's advice: http://www.rennsportsystems.com/1-e.html
    Harry
    Member #789
    2009 MB C300
  1. 1970 911 E rear bump panel
    By peko in forum Technical Info
    Last Post: 10-31-2013, 04:57 PM
  2. WTB: Front Condenser "Bump Bars" Early AC Car
    By drvee12 in forum For Sale: 911 Parts
    Last Post: 04-13-2013, 05:37 PM
  3. WTB: Stock 19mm Torsion Bars
    By t6dpilot in forum For Sale: 911 Parts
    Last Post: 03-24-2010, 07:55 AM
  4. ST/ R Roll bars back in stock !
    By TRE Cup in forum Technical Info
    Last Post: 12-27-2007, 04:58 AM
  5. Cost to bump 2.0 to 2.2
    By berettafan in forum Technical Info
    Last Post: 04-13-2006, 08:33 AM
