Could someone id these rear calipers..They came in a box marked 71', along with a pair of aluminum fronts. Thank you.
________________________________
Jon
6?' 303129
Eric (Neunelfer) will hopefully chime in here but they look
like wide-M to my untrained eye.
andy
67S in pieces
EarlyS: 1358
[SIGPIC][/SIGPIC]
They are not a matched pair. The one on the left is a standard 911 wide M with 38mm pistons meant for a vented rear rotor. The one on the right looks more like a 914/4 front, but it is hard to tell without more photos. The piston should be measured, I need to know if the spacer width is the same as the left caliper, how many bleed nipples, and what the bolt heads look like. It may be a 911 M front as well.
Hey, Thanks guys! I'll take some more photos tomorrow and try and get them up. Also spacer specs.
Jon
6?' 303129
The caliper on the right has a 7mm spacer, while the one on the left is 10mm. Each has (1) one bleeder. The ribe head bolts on the left caliper are about 7mm, while the ones on the right measure 8mm. Mounting hole spacing on each is 3". Is this enough info, or is the piston diameter necessary? Thanks again for the help!
Jon
6?' 303129
That looks to be a left hand front caliper for vented discs with 3 inch ears and a right hand rear 69- for vented discs.
Just a quick rule of thumb, on front calipers the inlet pipe is in the middle of the caliper and on the rear it is at the bottom, plus you can normally tell by the size of the piston. & Bleed nipples are always at the top.
HTH
Alan
Alan is correct, the one on the right is a front 911 M caliper for vented rotor with 48mm pistons. So you have one front and one rear.
Thank you Alan and Dave. Appreciate thehelp.
Jon
6?' 303129
Thank's guys. I appreciate the help.
Jon
6?' 303129
Always late to the party
But... you're always in good hands with Dave and Alan. Spot on detective work.
However! They "might" be big reds from the looks of that rattleca... errr, factory powdercoating on there.
Eric - Sandy, Utah
71 911
914-6/GT
914-6/ORV
87 944 Spec 1
Porsche Truck
62 Beetle
80 VW “Caddy” Pickup
72 R75/5 Toaster Tank
PMB Performance
Love Us On Facebook
