Ok intalled my newly rebuilt MFI pump today. Mostly went well, but not quite. I can not seem to get rid of an idle lean misfire, and when I accelerate, the car lacks power but does alringt at about 3K rpms. It wil complain with some more lean misfires and some jerling when asked to accelaerate at the low end.
All my reading tellmes me that this is most likely a pump adjustment tocorrect the fuel delivary. Make sense to me, but I have made some big time adjustmets. Here is what we have done thus far.
Made sure the z1 marl and the pump mark were matched up. When we first started the car, the main rack adjustmet was lean as hell, we came counter clock wise about 4 clicks and got it to fire off. Seemd to do oK at the top end, but the idle was faurly smooth, but losts of popping. Adjusted the idel mixture, but could never get the popping completely out.
Did a test drive, and I would say the car was OK, but not a porsche. It had an identity crisis that I described above. Brought it back and adjusted the main rack with two more counter clock wise clicks, and this may have made things worse.
I have a gunston CO meter, but I can not seem to get the idle mixture below 10%. Unfortunatley I think I might have an oil burn that may be making that thing usless. Not 100% sure about that, but I have my suspicions.
OK I am reluctant to go move aggressive on the main rack. I have a 71E and I have turned it 6 clicks already. I read that I have 12 on this model year. I also think the pump may have been shipped all the way lean, but I will have to wait until tomorrow to confirm. Supertec rebuilt this for me, and they have been great and told me they will help tomorrow. I will let you know what they say.
Is there something else I could be missing. DID the CMA, and all that is OK. I have the stacks synched fairly well. I have no way to test the injectorsm and I am wondering if a bad injector could be causing my issues because most of my problems appear to be coming from one or two cylinders. Fianlly what does a rich MFI engine look like. Because I have lean misfires and poor acceleration, I am assuming that this is a lean issue. I have been 180 degrees wrong in the past
Thaks for advice if you offer it. As noted earlier, I will post a follow up.
