Thread: carrera RS rims color codes
    Ready for the Hunaudières manu72S's Avatar
    Nov 2004
    Hi
    Do you know the fuchs color codes for a Carrera RS ? I am looking for blue, green and red codes.
    thanks
    Manu
    As I understand it the blue is Mexico Blue, the green is Kelly Green and the red is Bahia Red
    Cheers
    Paul
    Early911S member #1398
    50 356 Cab
    57 356 Carrera
    61 356 Roadster
    73 RS #0073
    79 930 Turbo
    93 3.8RSR
    Rs wheel colour
    Does anyone know the colour code or name of the gold on the 74 RS wheels?
    David Withers
    68 912 Sand Beige
    73 911E Sepia Brown
    74 Carrera 2.7 MFI - GP White
    75 Carrera 2.7 MFI Targa - Sahara Beige
    95 Carrera RS - GP White
    02 996 Turbo - Black
    07 997 Turbo - Black
    R Gruppe #449
    Early S Registry #1037
    Aust Typ 901 #113
    May 2005
    Oroville, CA
    I have matched colors on factory new, aftermarket and on unrestored cars.
    I found the red on unrestored and factory stripe is usually closer to Bahia than Guards until recently I received some old stock and strangly enough they were Guards. Most aftermarket are way redder than Guards or Bahia.
    The green is usually very close to Viper or Conda on both factory and aftermarket. I use the factory formula as a start.
    The blue causes the most problems. I have never seen a factory or aftermarket stripe even close to Mexico. The confusion comes from the books referring to Mexico. My best guess is that the Mexico blue discription was different in 72 than for the production color for 74 cars. A good example is Glacier Blue..it is a very different color from 70 to 83.
    The main thing is that they could not match the wheel paint very close to the vinyl used for the stripes. If you study a unrestored car you will see that they don't match as well as current restorers do.
    All are custom formulas to match the stripe that you order even the 74 Gold.
    Hope this helps.
    H
    Harvey; Sent you a PM ;Thanks
    Aziz ; VARIOUS PORSHAS
  1. Interior color codes
    By davep in forum Technical Info
    Last Post: 02-01-2024, 01:49 AM
  2. Replies: 2
    Last Post: 10-05-2011, 04:21 AM
  3. color codes
    By tp67911s in forum Technical Info
    Last Post: 07-12-2006, 03:58 PM
  4. Help with Early 911 color codes
    By gregsy in forum General Info
    Last Post: 08-10-2005, 05:42 AM
  5. Color Codes
    By RandyWebb in forum General Info
    Last Post: 06-12-2005, 09:59 PM
