I spent more than a few hours Sunday replacing the driver side power window motor. The access to removing the three bolts which the motor is mounted to was highly restricted to say the least. Today I purchased a 10mm ratchet wrench to aid in removing the bolts on the passenger side but there must be an easier way to access those bolts or drop an assembly to access the bolts. Can't locate any related threads on an early car here or on the Penguin site.
Thanks in advance.
Edit: Solution: The 10mm ratchet wrench was exactly what was needed. On the passenger side, it took less than half the time, including cleaning all connections, lubing all parts, and watching the In Living Color marathon.
