Results 1 to 10 of 11
Thread: Ready for paint, final deatils?
    Semjon Semjon's Avatar
    Jun 2005
    Groningen, Netherlands
    I’m in the process of getting ready for paint. All the bodywork is done and the car is in the final stage of preparation before paint.
    I would like to have all details period correctly done.
    The car is going to be painted in it’s original color; Light Ivory (Hell Elfenbein), color code 6604.
    The car is a 65 build, 66 model year with 4 screw horn grilles.
    I already found a lot of details and information but still have some questions or things that I’m not sure of;
    - The body will be painted inside and outside, after paint undercoating will be applied to the wheel wells and underside. After undercoating these areas will be sprayed satin black. Correct?
    - The area where the engine grill is mounted on the deck lid will also be satin black
    - The complete inside of the engine room will be satin black, including the hinges. Is there undercoating applied to the engine room or just paint?
    - The complete inside of the trunk will be satin black, including the hinges. Is there also undercoating applied to the inside of the bonnet?
    - The front cowl area where the fresh air inlet is attached should be satin black. Applied with a brush?
    - What about the area behind the horn grilles? Body color or also satin black?
    - The inside of the car, I’ve found multiple pics of cars that are completely painted black on the inside but also a lot of cars that only have black paint around the edges and corners. What is correct or does this depend on build date?
    - The inside edges of the doors going to be satin black
    Hope someone could shine some light on this. Thanks in advance!
    Early 911S registry member #1391
    Built '65, MY66 911 in total restoration
    Quote Originally Posted by Semjon View Post
    Hell Elfenbein, good! Single stage or basecoat/clearcoat? Single stage is correct, but it's pretty hard to find it in the right colors these days. Basecoat/clearcoat is the modern equivalent and will look incredible, but won't be original.
    Usually you just shoot Wurth SKS undercoat which is already black, it's kind of blue (a miles davis reference) when it goes on. Be careful to practice first so you can replicate the factory buildup. I would not shoot satin over the top.
    Dash and dash top satin black, around the seat tracks, down the center tunnel, down to the floor in front behind the pedal boards. I've never seen an interior that didn't have either rust or horsehair pads in the floor, so I don't know if the floor was black, but I sort of doubt it given the rust I've seen on every car I've looked at. The seat pans and up inside the roof, body color overspray. Bottoms of the doors also satin, where the door panel reveals the metal of the door. (this is left off a LOT of cars) Nobody will see if you do too much black.
    Behind the fresh air vent, inside the engine lid grille opening, both black. Probably a brush as you say, albeit precisely so. Back of the front and rear bumpers is body color, I don't think there is any black behind the horngrills.
    Good luck!
    Jun 2005
    Hi John, thanks for your reply!
    I know single coat is original.. still in doubt. Indeed very difficult to find and not a lot of painters who know how to apply it correctly.
    Thanks for the answers, they really help a lot!
    The use of Wurth is a good tip.
    Will post some pics of the whole proces in a couple of days/week.
    Thanks!
    Sep 2006
    La Quinta
    What I have found is: the inside of the horn grills is also black. And the underside of the front hood was undercoated first(just the flat part), then painted body color. Also, the inside of the engine room is undercoated, but only on the hard surface.
    Everything else sounds good.
    Can't wait for photos!
    1962 356 Cab, show car, sold.
    Registry #983
    R Gruppe #741
    Jun 2005
    So the inside of the fender where the horn grille is attached should also be black? Thanks for the tip! Also on the undercoating.
    Nice to have all the details correct
    Sep 2006
    La Quinta
    Good luck,
    Registry #983
    R Gruppe #741
    Senior Member mrgreenjeans's Avatar
    Nord Stern Region of PCA....west coast side of Region
    Great pic of the 914-6 GT , John !
    Love the look....will it be at Parade in Keystone ?
    Best Regards,
    mrgreenjeans
    member # 1503
    -'68 -912 Red
    -'74 -914-2.0 litre - Sunflower
    -'82/83 -944 -M404 - Guards Red
    -'84 -944 -M456 - Guards Red -Weissach Prep. -H52
    -'84 -944 -M456 - Zermatt Silver
    -'84 -944 -M404 - Sunroof Delete - Ruby Red
    -'85.2 - 944 -M456 -Zermatt / Sport Purposes
    -'86 -944 -R74 Spt.Touring Pkg - White/Burgandy
    -'88 -944 - Jubilee Ltd. Ed. -Satin Black Met/Grey Plaid
    -'88 -911 - Tourist Delivery -Venetian Blue
    -'89 -944 Turbo M030 - Satin Black Met.
    Sep 2006
    La Quinta
    No mister Green,
    We will be, but not the car...getting it ready for Monterey. If we get in?
    You never know until the last minute.
    Registry #983
    R Gruppe #741
    Jun 2005
    Update :)
    The prep work is done and the inside is already painted (Light Ivory, the black will follow later)
    Body is expect back tomorrow...
    More pics will follow!
    Jun 2005
    Freshly painted!
  1. FS: Headlight rim new old stock cad plated ready for paint
    By hwgunner in forum For Sale/Wanted: Other Porsche Cars and Parts
    Last Post: 12-19-2013, 12:37 PM
  2. Tips for getting ready for paint
    By Eli in forum General Info
    Last Post: 03-05-2013, 02:55 PM
  3. The Dos and Don'ts When Getting Ready For Paint
    By bxd in forum Technical Info
    Last Post: 11-08-2012, 10:51 AM
  4. Getting ready to paint...
    By chicagobreezz in forum Technical Info
    Last Post: 02-04-2008, 01:21 PM
  5. 1971 911S Tub ready to paint
    By charlestonius in forum General Info
    Last Post: 12-27-2003, 08:33 PM
