Guru I didn't see you other post till just now, think I have a lot of bad news for you when you see the pics
Clyde Boyer
Early S Registry Member #294
TYP 901 Register Inc #6
that doesn't sound good.
waiting nervously...
thanks for your help, Guru
Guru Sivaraman
1972 S
1977 3.0 Carrera
Early S Reg. #1199
Its nightime here I have both recaros out and the carpet just trying to pry up some of the original carpet without damaging it so i can get the best pics possible for everyone
I am going to look at your thread closely now to see if I can help
Clyde Boyer
OK here we go seats, carpets and pedal boards removed.
Drivers side first
In order pedal cluster, gear change tunnel area, centre of floor under seat, rear floor, handbrake area, tunnel cover removed and under the carpet covering the tunnel cover
All black paint has been sprayed and very lightly at that and its all matt balck
I am 99.9999% certain dash to should all be black Frank
Any more pics required now is a good time to ask
I did notice that someone has replaced the alloy brake fluid lines with plastic blue ones have to get on to fixing that!!!
Clyde Boyer
Last of drivers side passenger side coming soon
Clyde Boyer
OK passenger side front wall, gear change, centre floor under seat, handbrake and rear floor
Clyde Boyer
Sorry about the shadows.
Under the carpet in front of passenger seat side rocker panel looking from inide the car to oustide some red some black, same thing but rear of passenger seat all black , brackets where rear seats pivot also painted black as Brian suggested yesterday
Clyde Boyer
You can clearly see where the matting has been trimmed/cut to shape and fit everwhere. On the passenger firewall its also a piece of black bitumen but for some unknown reason its gone a funny blotchy colour.
You have about a 3 hr window for more pics before I put it all back together again
Firewall is black all the way to where it intersects the floor and a little beyond into the floor area
Clyde Boyer
Hello Frank:
First, I assume that you are restoring an RS sport or a car to specs as per RS sport.
Here is my opinion:
RSR was converted from RS sport. RS sport had no sound deadener on the floor.
The RS sport had "gummimaten" (rubber mats) on top of the painted floor. The black paint was to keep the color from showing between the edge of the gummimaten and the needle point felt carpeting.
Maybe the color on the floors did not have as high a gloss because they used less paint on the interior then we like to see nowadays.
The RS touring did have sound deadener applied to the floor as well as velour carpets. I suspect all this was applied on top of the color and satin.
Local shop here does black satin on the floor when restoring an RS sport in the same manner as the RSR photo Raj posted. Dash top all black. Footwell all black most of the way down to the floor just like in the image Raj posted.
Newton's RS sport Manhattan winner of many moons ago had the floors done like the RSR in Raj's post.
Early 911S Registry
Looking for engine 960 168
Looking for gear box 103 165
Yes the visible red paint in the cabin is very washed out nothing like the paint on the exterior more like the back of the front trunk area where it looks like they barely covered the steel with paint
Black is very matt and whoever did the doors must have had a steady hand if its hand done as the lines on the RS are fabulous around the corners of the doors
Clyde Boyer
