Thread: '68 911 Brake Caliper Bleeding Nut Position
    Senior Member 68911USA's Avatar
    Jan 2009
    Salisbury, MD
    Uh...I might have really done it this time! I have had all four brake calipers rebuilt and reinstalled them on the car. I now have a fluid leak from the top of the master cylinder that will eventually drain the container all the way down if I pump the brakes to try to build pressure in the system. Everything in there looks okay, as in the lines seem to connect properly to the top of the master cylinder, and the seals look good and pliable. The master cylinder is supposedly less than a year old. After looking at some photos, it would appear that the brake bleeding nuts (nipples?) on my car are all pointed DOWN TOWARDS THE GROUND, and I am wondering if this is the problem. If I have put all four calipers on BACKWARDS, this would cause this orientation difference, and maybe helping cause a pressure problem in the system that could be causing the leak. If I take all the calipers off and swap them side to side so the bleeders POINT UP, is this what I should do? I also replaced all the rubber lines from the hard lines to the calipers while I was having them rebuilt. Once again, my DIY project has taken a turn! Thanks a ton, it never occured to me to pay attention to this detail before I bolted them all on again!
    1968 Porsche 911 #11830133 (2009- 2012)
    1968 Porsche 911T #11820522 (1997-2007)
    Registry Member #1536
    Hagerty Insurance Guy
    Missing my Porsche. Need to find another SWB project!
    Current cars:
    1918 Willys-Overland Model 90BT
    1966 Sunbeam Tiger Mk1a
    1977 Chevrolet Suburban C20 "Trailering Special"
    1983 Ferrari 308 GTS Quattrovalvole
    1992 RHD Toyota Century
    Jan 2009
    Salisbury, MD
    Answered. Looks like I will be swapping the calipers around! I've done it again...
    Current cars:
    Senior Member Neunelfer's Avatar
    Dec 2002
    Sandy, Utah
    Bleeders (and air bubbles) are always at the top. Fun huh?
    Eric - Sandy, Utah
    71 911
    914-6/GT
    914-6/ORV
    87 944 Spec 1
    Porsche Truck
    62 Beetle
    80 VW “Caddy” Pickup
    72 R75/5 Toaster Tank
    PMB Performance
    Love Us On Facebook
    Jan 2009
    Salisbury, MD
    ...and it still leaks. I think when I moved it around to remove/reinstall the pedal cluster, I unseated the gravity lines. Can't seem to get them to seat any farther down, either...
    Current cars:
    Dec 2002
    Sandy, Utah
    I was afraid of that. Those are very tough... I don't really know what to tell you. You should probably get new grommets and get everything seated properly. Although... most M/C's come with new grommets. They may be ok but, take them out, seat the lines and reseat the grommets at least.
    Good luck.
    Eric - Sandy, Utah
    71 911
    914-6/GT
    914-6/ORV
    87 944 Spec 1
    Porsche Truck
    62 Beetle
    PMB Performance
    Love Us On Facebook
    Oct 2008
    Burford, ON, Canada
    The MC has washers in the holes for the metal tubes to seat on. These washers are under the rubber grommets. Without the washers the tubes go in too far and may not seal. Not much to do but to loosen everything and try to find out if the washers are there, then try and get the tubes to seat correctly. It can be a real bear, having done it a dozen times or more. Sometimes I move the pedal cluster back to get more wiggle room. You can never get air bubbles out of calipers with the bleed nipples on the bottom.
  1. Brake Caliper Locked up
    By red911 in forum Technical Info
    Last Post: 09-08-2012, 06:22 AM
  2. FS: Weber & ALU brake caliper
    By typ901 in forum For Sale: 911 Parts
    Last Post: 06-12-2011, 08:08 AM
  3. rear brake caliper
    By Francois Duval in forum Technical Info
    Last Post: 11-30-2009, 05:26 PM
  4. Brake Bleeding snafu - need help!
    By wolfturbo in forum Technical Info
    Last Post: 07-09-2003, 11:37 AM
  5. Brake Bleeding snafu - need help!
    By wolfturbo in forum General Info
    Last Post: 07-06-2003, 03:14 PM
