Results 1 to 10 of 12
Thread: How to Restore a Pitted Headlight Lens?
    Aug 2006
    Chicago area
    I have a set of SWB Hella headlight lenses that I need to restore. They have been "sandblasted" by the many miles on the road over the years. No really large pits, just lots of little ones. I am sure someone here has restored these and can share their experiences. I was planning on sanding them with 400 grit sandpaper, subsequently moving to finer and finer grit, and then finishing off with one or two grades of polishing compound.
    Is this the correct method that others have tried or are pitted glass lenses unrestorable? Thanks.
    Scott H.
    1969 Coupe LtWt
    1973.5 911T
    bob moglia
    '72 E sunroof coupe
    Glass Polishing
    Early S Registry #1227
    912 Registry
    PCA - Sequoia Region
    You can use those glass polishing kits which will help, but you will never get all the pits out no matter how hard you try. But you can make it look better with the kit.
    Aug 2006
    Chicago area
    Thanks guys. That is kind of how I thought the process would work. I'll give it a try and post results.
    Hey Mike, I had the 71 out today for the first time this season. Drove right by your house (well sort of) Gotta get together this season.
    Scott H.
    1969 Coupe LtWt
    1973.5 911T
    You did Scott? Cool I am jealous.
    My '68 is still missing engine, trans and rear suspension, but it's rapidly going back together, should be done by end of month. Rebuilt carbs, rebuilt disty, new TO bearing, tons of new little parts, reundercoated, repainted bits...should drive even better this year!
    My '68 wants to stretch it's legs and DRIVE!
    Scope Creep Poster Child
    May 2003
    Eugene, Oregon
    Scott-
    Did you have any luck with this?
    Early S Registry 1047
    ’15 VW GTI
    '70 911E, Sold
    '56 Cliff May Prefab
    Sep 2006
    La Quinta
    Good question...has anyone tried this?
    1962 356 Cab, show car, sold.
    Registry #983
    R Gruppe #741
    Aug 2006
    Chicago area
    Scott, I sanded one lens with 240 and then 400 grit sandpaper, then tried polishing with compound I use in the detail business. No joy! I did some research on the Eastwood products and all I found were so so reviews. I decided to save my $$ and buy new repros. Maybe I will give it another try this w/e. If I have any success, I will report back.
    Scott H.
    1969 Coupe LtWt
    1973.5 911T
    May 2003
    Eugene, Oregon
    Scott-
    The research I did found someone recommending starting with 600 and going finer from there. Here is a link that shows them claiming success:
    http://volvospeed.com/Mods/glass_polishing.html
    Perhaps 400 is too coarse to polish out? He was pretty specific about the polising compound used, also.
    ’15 VW GTI
    '70 911E, Sold
  1. FS: OEM H4 Headlight Lens
    By juche_namja in forum For Sale: 911 Parts
    Last Post: 01-15-2015, 03:06 AM
  2. How do you restore the silver taillight lens trim?
    By X-Faktory in forum Technical Info
    Last Post: 02-20-2013, 09:01 AM
  3. FS: H1 Headlight Lens
    By CurtEgerer in forum For Sale: 911 Parts
    Last Post: 01-08-2013, 03:14 PM
  4. Restore Pitted Headlight Lenses?
    By Scott Clarke in forum Technical Info
    Last Post: 12-30-2009, 11:57 AM
  5. VW headlight lens for the 911?
    By Burint in forum General Info
    Last Post: 05-03-2007, 09:24 AM
