Thread: matching of oil level gauge to sender?
    912->911 conversion
    Nov 2004
    Calgary, Alberta, Canada
    As I progress (?) with converting my 912 to 6 cyl, I was wondering if the oil level gauge in the dash has to be date matched to the sender in the oil tank used? Since the oil level sender design changed year to year, I was wondering if I put in a 1971 tank if that means I need a 1971 gauge since the 1972 and 1973 senders were different.
    Or, if the output range of the senders is all the same and any gauge will work.
    Cheers!
    Keith Adams
    Early 911S Registry #906 | PCA member IG: @912R
    1969 Blutorange 912R - 912 to 911 conversion
    1969 Mercedes 280 SE (W111) Coupe
    912->911 conversion
    Nov 2004
    Anyone? Beuhler?
    Does anyone know the output voltages of the oil senders? I.e. if you don't have a gauge hooked up, to check them with a voltmeter?
    Keith Adams
    Senior Member SpawnyWhippet's Avatar
    Mar 2013
    San Francisco Bay Area
    I have the tank out on my 72 T, sorting out some oil leaks.
    My sender unit reads from 0 to 180 ohms, but I have no idea if that is correct and accurate.
    Member # 2899
    1972 911T
    2004 996 C4S
    2001 996 Carrera
    2008 Cayenne S (sold)
    2004 Cayenne Turbo (sold)
    2009 997 cabriolet (sold)
    2002 996 Turbo (sold)
    1998 Boxster S (sold)
    1997 993 cab (sold)
    1989 911 3.2 Carrera (sold)
    I can't give you a 100 % answer, but I'll bet they're all the same gauge wise. A call to North Hollywood or Palo Alto would give you the definitive answer.
    I would match the tank, sender and gauge to model year. I would consider 70-71 to be the same. gled
  1. Replies: 3
    Last Post: 04-09-2014, 02:23 AM
  2. Matching oil temperature sender to gauge
    By lkadams in forum Technical Info
    Last Post: 05-02-2011, 09:01 PM
  3. WTB - '67 oil level/fuel level gauge and screw on shift knob
    Last Post: 03-31-2011, 11:29 AM
  4. Oil Level Gauge/Sender Diagnosis
    By jkolesa in forum Technical Info
    Last Post: 08-08-2010, 01:51 PM
