Results 1 to 10 of 10
Thread: Ignition Wires any difference?
    Looking for a set of new wires for the 71 911S and I see that there are numerious ways to go. I'm a traditionalist and would like to keep the car pretty much OEM, but not Concor intense, so I am open for improved wires if they really make a difference. I see that there are the OEM for $250, Breu for $150, and a countless line of wire manufacturers from $69 to $300 and more. Anything I should be looking for and does the premium wires make a substantial difference in relation to price? Thanks for your comments, Allan
    1974 914 2.0 Yellow/Black
    Oct 2005
    Minneapolis, MN
    I like the Beru wires....great quality and look correct. Sometimes, I custom trim them to length.....
    Aaron Hatz
    Flat Six, inc.
    www.flat6.com
    Follow us on Facebook
    www.facebook.com/flatsixinc
    I have Clewett's on my Race Car, they are fantastic. Quality of the boots is great and no more worrying that you're going to yank the wire out of the "beru" connector or leave those rubber insulating washers down inside the head. For as often as you pull the plugs on an MFI race car, they are indispensable, and not that expensive. Clewett fixed all his issues with water ingress that you may read about here and there- they really are a great product that snaps nicely into place and holds on the plug well.
    Feb 2005
    Lake Tapps, WA
    +1 on the Clewett's...not exacltly original looking but not bad either if you get the black ones.
    '67 911S
    '69 911S
    '70 911ST
    '73 911T Targa Signal Yellow
    '11 Spyder
    Early S#1097, R-gruppe #
    I like the Magnacor Electrosports 70 wires as they are black and the same 7 mm diameter as originals, but offer better protection from stray signals and have good plug end fittings that stay together. A stock length set is around $130-140.
    http://www.magnecor.com/magnecor1/main.htm
    Gib Bosworth
    EarlySReg 434
    R Gruppe 17
    Does the Clewett's come with a coil wire? I checked on the Pelican site and while all the others, Magecore, Breu, etc., shows a coil wire, the Clewett's did not. Was that just an oversite? Thanks Allan
    Feb 2005
    Lake Tapps, WA
    I have ordered three sets of Clewetts...'67, '79 and '87. They all came with a coil wire. For one set I relocated the coil wire and needed a longer wire. They were very accomodating and happy to make my custom length.
    '67 911S
    '69 911S
    '70 911ST
    '11 Spyder
    Dec 2004
    Same experience as Endo911rs
    Relocation of the coil required additional length for the coil connection. Avoid the problem by measuring and informing the manufacturer at the time of order. Clewett will make it any length you need.
    [SIGPIC][/SIGPIC]
    1967 911S Coupe
    1991 944S2 Coupe
    Past projects:
    1967 912 Coupe
    1969 911T Coupe
    1985.5 944 SR Coupe
    Regis turd ab user
    Dec 2006
    Tacomatose, Wa USA
    I installed Beru's on my carbureted 2.7 in my '71.
    The fit, length, performance, price and being black were all good for me.
    Relaxed Rich Lambert's Avatar
    Jun 2007
    Lake Stevens, WA
    Clewetts seem to be pretty heavy duty with big easy to grip boots and the distributor end is numbered, which is helpful for people who might cross wires...not that I've ever done that.
    Rich
    1966 911 #303872
    ES#1197
    RG#478
  1. Ignition wires
    By Merv in forum Technical Info
    Last Post: 05-28-2013, 02:06 PM
  2. Replies: 5
    Last Post: 07-27-2007, 04:58 AM
  3. Ignition Switch Wires
    By B D in forum Technical Info
    Last Post: 06-19-2007, 01:47 PM
  4. Nology Wires
    By Jim Calzia in forum General Info
    Last Post: 01-11-2006, 11:02 PM
  5. wires
    By deoxford in forum Technical Info
    Last Post: 02-15-2004, 06:55 PM
