Results 1 to 10 of 10
Thread: RSR / ST mfi pump tensioner "kit"
    Aug 2003
    Van Nuys, Ca
    We just completed making a run of these. If you own , or are building a replica ST or RSR with mfi,then this is what you need to help finish detail the engine.
    The threaded pieces (banjo, spade, and hollow bolt, are Chrome moly, the hex stand is stainless steel,the hex centered adjuster is anodized aluminum, and the angle plate and spacer will be plated in gold zinc, or silver cad (your choice) . Not shown in the picture is the jam nut for the adjuster. This will work with either oil fed or stand alone oil supply in the pump.
    These are limited run parts and very high quality. We are offering a few sets at intro price of $899.
    Please e mail me directly at tremotorsports@gmail.com
    original unit shown in first picture for comparison
    Member #755
    Conda Green 70 911S
    70 black 914-6 3.2
    70 911 "Speedster" project
    "74 IROC" tribute Jade Green RSR
    Aug 2003
    Van Nuys, Ca
    rear view of the tensioner assy and oil pressure sender special parts
    Member #755
    Conda Green 70 911S
    70 black 914-6 3.2
    Are you supplying as part of your kit the mounting plate with rubber bushes the mfi pump actually sits on, when using a support bracket?
    Mike
    cheers, Mike
    Member#1664
    1972 911 S/RSR to Martini Prototype specification
    http://www.ddk-online.com/phpBB2/viewtopic.php?t=15294
    Aug 2003
    Van Nuys, Ca
    Hi Mike
    I don't have the specs for that set up, but would be happy to duplicate them to make the kit more complete.
    The price posted is without the bushing set up you describe
    Thank you
    Dave
    Member #755
    Conda Green 70 911S
    70 black 914-6 3.2
    Pump?
    Does the arm come with the pump? LOL? Is that Max Crawform fiberglass?
    Aug 2003
    Van Nuys, Ca
    It is Crawford Composites glass kit. Nicely molded, BUT as it comes untrimmed or fitted, it makes for a very time consuming, if not pricey install.
    Still they have the amber tint , unlike the current european offerings we've seen that are clear green
    Member #755
    Conda Green 70 911S
    70 black 914-6 3.2
    I have often wondered what kid of tolerance these pumps have for belt stretching. I guess they were concerned enough to put them on their race egines. I just wonder why they didn't put a spring loaded pulley instead.
    I am curious how you loose the foot to rotate it.
    What effect does a stretched belt make on such a critical timed devise?
    Olin - Member #1375
    1972 911T
    Original
    Options added
    Are you sure about the bush mounting on the end of the bar where it joins the pump? On all the supposedly originals I've seen it's the same at both ends, a round forging for the bush as pictured in these examples.
    cheers, Mike
    Member#1664
    That's a detail that I had never noticed. It's interesting to think that as the factory wound these engines up more and more, they had to add structures such as this to keep the whole package together at high revs. Thanks for sharing the info.
    Peter Kane
    '72 911S Targa
    Aug 2003
    Van Nuys, Ca
    Hi
    Our tensioner kit is available with either the spade mount , as shown in the earlier post, or the rubber banjo mount .
    Please contact us for pricing details on either. We have inventory
    thanks!
    dave bouzaglou
    Member #755
    Conda Green 70 911S
    70 black 914-6 3.2
  1. FS: "Rare" 1968 Porsche 911L 911 L Smog Pump
    By trunos73rs in forum For Sale: 911 Parts
    Last Post: 10-25-2013, 06:44 AM
  2. Replies: 4
    Last Post: 10-27-2012, 08:16 PM
  3. FS "RS" "RSR" Special Extended Hub Thick Grip 380mm Steering Wheel
    By Allen Henderson in forum For Sale: 911 Parts
    Last Post: 03-17-2012, 07:56 AM
  4. FS "RS" "RSR" Special Extended Hub Thick Grip 380mm Steering Wheel
    Last Post: 01-24-2012, 01:59 PM
  5. Replies: 0
    Last Post: 06-10-2008, 02:16 AM
